Sorry da war ich zu schnell
Sie ist Wasser gekühlt, Aufnahme ist ER11
Technical Parameters for Spindle Motor
1) Diameter: 80mm x Length:188mm (including air interface: 80mm X 203mm)
2) Power: 1.5 KW
3) Voltage: 220V~250V (We also stock 110V~120V item for country like USA and Canada. Please contact us for item stock)
4) Frequency: 400 Hz
5) Speed: 8000-24000 R/min
6) Water Cooling
7) ER11(3.175mm,4mm,6mm) collet chuck
8) Runout off: less than 0.005mm
9) Grease Lubrication
Technical Parameters for Variable Frequency Drive Inverter
1) Inpute Voltage: 220±15% (We also stock 380±15%, please contact us for item stock)
2) Output Voltage – 208-240VAC (analogous to Input Voltage)
3) Inpute Frequency: 48-63 Hz
4) Outpute Frequency: 0-400 Hz
5) Inpute Phase: suit for 1 phase input, and also suit for 3 phase input
6) Outpute Phase: 3 phase
7) Item Manufactuer: From a well-known manufacture who manufacture VFD for more than 12 years
LG Thomas
