Servus,
hat jemand Interesse an einem Explorer Bee - original verpackt. Komme einfach nicht dazu ihn aufzubauen.
Hier mal die Daten:
Explore the vastness of the sky and enjoy the freedom of flight with the ExplorerBee.
Designed from the start to be a great flying wing platform for FPV flying. The ExplorerBee's unique camera bay, large central compartment, lightweight EPO foam combines to make this flying wing an FPV pilots dream.
The frontal section of the fuselage is crafted to fit your choice of action camera to give you an unobstructed field of view to fully immerse the FPV pilot. The outer wings have compartments to fit your radio receiver in one and video transmitter in the other to help separate the electronic noise.
The ExplorerBee has a smooth flight envelope, the wing has carbon spars and an RSB22 airfoil that enable a stable slow speed flight perfect for FPV, But when you want to push the limits it performs as well as a combat flying wing.
Endurance is another feature of FPV flying and with the ExplorerBee's large battery compartment you can use anywhere between 2600 to 3600mAh 3S LiPoly giving the pilot many minutes of flying adventure. Partnered with a brushless outrunner and electronic speed controller and your choice of many different FPV electronics and you're ready to Explore and own the sky.
With the ExplorerBee the adventure begins here.
Features:
• Unique FPV flying wing
• EPO foam construction
• Large battery bay
• Smooth flight envelope
• Designed for GoPro/action cameras
• Wing compartments for VTX and RX
• Almost ready to fly kit
Specs:
Wingspan: 1020mm
Length: 360mm
Airfoil: RSB 22
Weight: 870g (Flying weight)
Material: EPO foam
Included:
1 x Explorer BEE FPV flying wing
1 x Instructions
Required:
Minimum 4 channel Transmitter and receiver
Brushless outrunner motor (1200~1600kv)
Brushless Electronic Speed Controller (30A)
2 x servos (9-17g)
1 x XT60 Plug (Male)
Your choice of camera, video transmitter or FPV equipment
Adhesives and general building tools
Bei Interesse gerne Pn
Paypal und Versand möglich!
Preis: 75€
Hier mal die Daten:
Features:
• Large battery bay
Specs:
Wingspan: 1020mm
Length: 360mm
Airfoil: RSB 22
Material: EPO foam
Included:
1 x Instructions
Required:
2 x servos (9-17g)
Preis: 75€
