Naza-M how to adjust?
broland
Hello.
I managed to buy a Naza V1, and the ring would be my question as to how to set it up?
If the basic gain is adjusted to what is changing (what I'm picking up on the machine), if the value is low or when high?
If windy wobble, which parameter is wrong?
If descent wobble to do?
If the basic gain is high, the attitudes to gain what? Low or high?
Are you people who are already used to fly with Naza, help in configuring please.
Thanks in advance.
Regards Roland
broland
Hello
The copter is hexY6, cc 3kg. Props rctimer 13x4" carbon, motors rctimer bc3536-11.Gains:125,125,115,120 115,115
Thanks Roland
broland
Thank you for your answers.
But if you reduce the value of the basic gain, then what should be the atti gain?
And Yaw, and Vertical Gain value?
This page has been seen, but I could not find similar, and the values ​​read it I did not find it appropriate for me to value relationships.
The Basic Gains are for the leveling and stable flight
Pitch = Nick
Roll = Roll
Yaw = Gear
Vertical = Hold High
Atti Gains :
Atti Gains are like Expo for the Self leveling after Stick Kommandos when you let the sticks go to middle Position
Gains High for fast leveling.
