Würden die Teile so passen?
Power Distribution brauchst du nicht wegen dem Regler... Motoren passen nicht zum Regler die Kabel schwarz und Rot brauchst du nur bedingt und je nach Akku musst du sehen welche probs du nehmen müsst :) gruß
Dosensuppe
Hallo, danke für die Antwort! Welche Motoren würden denn für den Regler passen?
Danke schonmal :)
PS.: warum ist mein erster Post verschwunden, oder bin ich nur blind?
Dosensuppe
Dann mach ich's halt so :)
1x http://www.hobbyking.com/hobbyking/store/__48111__20CM_Male_to_Male_Servo_Lead_JR_26AWG_10pcs_set_EU_Warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__36270__Nylon_XT60_Connectors_Male_Female_5_pairs_GENUINE_EU_Warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__30032__HobbyKing_E4_Balance_Charger_EU_warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__47809__Q_Brain_4_x_25A_Brushless_Quadcopter_ESC_2_4S_3A_SBEC_EU_Warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__38270__ZIPPY_Flightmax_2800mAh_3S1P_30C_EU_warehouse_.html
2xhttp://www.hobbyking.com/hobbyking/store/__34504__9047SF_Slow_Fly_Electric_Prop_CW_From_Rear_4_pc_EU_Warehouse_.html
2xhttp://www.hobbyking.com/hobbyking/store/__34506__Slow_Fly_Electric_Prop_9047_SF_4_pc_Green_EU_Warehouse_.html
4x http://www.hobbyking.com/hobbyking/store/__31698__NTM_Prop_Drive_28_Series_Accessory_Pack_EU_Warehouse_.html
4xhttp://www.hobbyking.com/hobbyking/store/__31699__NTM_Prop_Drive_28_26_1000KV_235W_EU_warehouse_.html
1x
http://www.hobbyking.com/hobbyking/store/__44307__5_6mm_x_24mm_M3_Nylon_Threaded_Spacer_10pc_EU_Warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__36299__Gyro_Flight_Controller_Mounting_Pad_10pcs_bag_EU_Warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__31696__Turnigy_Battery_Strap_330mm_EU_warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__41765__Hobbyking_X650F_Glass_Fiber_Quadcopter_Frame_550mm_EU_warehouse_.html
1xhttp://www.hobbyking.com/hobbyking/store/__42106__MultiWii_PRO_Flight_Controller_w_MTK_GPS_Module_EU_warehouse_.html
Upgrade 08/15
Du brauchst noch rechtsdrehende Propeller, sonst wird der nicht fliegen!
Motoren sind ok aber nimm die "short shaft" Version.
http://www.hobbyking.com/hobbyking/...V_235W_short_shaft_version_EU_Warehouse_.html
Die Motoren kannst du übrigens auch problemlos an 10'' oder auch 11'' betreiben. Mit einem 5000mah 3s Lipo kannst du dann locker 20 min+ FPV fliegen. Aber das brauchst du vorerst eh nicht.
Das Klettband zum Akkufestziehen ist Müll, nimm die neongelbe Version oder etwas ähnliches aus Deutschland: http://www.hobbyking.com/hobbyking/...p_Universal_Tie_Down_Flouro_Yellow_300mm.html
Der Lader schaut jetzt auch nicht allzu toll aus (ich kenne ihn nicht), der bekannte Imax b6 ist da schon besser. http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=50481
Momentan aber auf BK, im int. warehouse wäre er auf Stock. Dann kommt aber je nach dem noch Zoll + Wartezeit hinzu.
Bei den XT60 würde ich die Black-Version nehmen, die sehen einfach besser aus:
http://www.hobbyking.com/hobbyking/...ale_and_Female_5_Pairs_Bag_EU_Warehouse_.html
Achja, Schrumpfschlauch fehlt auf jeden Fall noch.
Upgrade 08/15
Hey,
Der ist zu schwer. Wenn 5000mAh dann die Zippy compact oder die spezielle Multicopter Serie. Den XT60 Stecker müsstest du bei dem von dir verlinkten Akku wohl dazulöten.
http://www.hobbyking.com/hobbyking/...apacity_3S_5200mAh_Multi_Rotor_Lipo_Pack.html
http://www.hobbyking.com/hobbyking/..._Warehouse_.html?strSearch=zippy compact 5000
Für den Anfang ist es aber sowieso besser, wenn du mit einem ca. 2200-3000mAh Akku fliegst, das macht mehr spass! Besser 2 kleine Akkus als einen grossen. Wenn du später Bock auf lange Flugzeiten hast, kannst du immer noch ca. 10'' Propeller und ca. 5Ah Akku nachrüsten!
