Inav Programm für Mini Talon
Habe mich wahrscheinlich falsch ausgedrückt.
Habe das Programm. Wollte fertige Einstellungen wie PID Werte usw.
Würde dann nur noch meine Servobelegung und Hardware anpassen
Sibi
Code:
# version
# INAV/OMNIBUSF4V3 1.8.0 Nov  1 2017 / 06:35:50 (912d1315)
# resources
# mixer
mixer CUSTOMAIRPLANE
mmix reset
mmix 0  1.000  0.000  0.000  0.000
mmix 1  1.000  0.000  0.000  0.000
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1510 100 -1
servo 3 1000 2000 1462 100 -1
servo 4 1000 2000 1462 100 -1
servo 5 1000 2000 1495 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
smix 0 2 1 -100 0
smix 1 2 2 -100 0
smix 2 5 1 100 0
smix 3 5 2 -100 0
smix 4 3 0 -100 0
smix 5 4 0 -100 0
smix 6 6 3 100 0
# feature
feature -RX_PPM
feature -VBAT
feature -RX_UIB
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DASHBOARD
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -SUPEREXPO
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -PWM_SERVO_DRIVER
feature -PWM_OUTPUT_ENABLE
feature -OSD
feature VBAT
feature MOTOR_STOP
feature GPS
feature CURRENT_METER
feature RSSI_ADC
feature BLACKBOX
feature PWM_OUTPUT_ENABLE
feature OSD
# beeper
beeper RUNTIME_CALIBRATION
beeper HW_FAILURE
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACTION_SUCCESS
beeper ACTION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper LAUNCH_MODE
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSED
# aux
aux 0 0 0 1700 2100
aux 1 1 1 1700 2100
aux 2 2 1 1300 1700
aux 3 26 4 1700 2100
aux 4 4 4 1700 2100
aux 5 3 4 1700 2100
aux 6 8 4 900 1150
aux 7 10 1 900 1300
aux 8 14 4 900 1300
aux 9 27 3 1675 2075
aux 10 28 3 900 1300
aux 11 18 2 1700 2100
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# master
set looptime = 2000
set gyro_sync = ON
set gyro_sync_denom = 2
set align_gyro = DEFAULT
set gyro_hardware_lpf = 188HZ
set gyro_lpf_hz = 60
set moron_threshold = 32
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 1
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 1
set vbat_adc_channel = 2
set rssi_adc_channel = 3
set current_adc_channel = 1
set airspeed_adc_channel = 0
set acc_notch_hz = 0
set acc_notch_cutoff = 1
set align_acc = DEFAULT
set acc_hardware = MPU6000
set acc_lpf_hz = 15
set acczero_x = 213
set acczero_y = -28
set acczero_z = -792
set accgain_x = 4095
set accgain_y = 4067
set accgain_z = 4003
set rangefinder_hardware = NONE
set align_mag = DEFAULT
set mag_hardware = NONE
set mag_declination = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set mag_calibration_time = 30
set baro_hardware = BMP280
set baro_use_median_filter = ON
set pitot_hardware = NONE
set pitot_use_median_filter = ON
set pitot_noise_lpf =  0.600
set pitot_scale =  1.000
set receiver_type = PPM
set mid_rc = 1500
set min_check = 1100
set max_check = 1900
set rssi_channel = 12
set rssi_scale = 100
set rssi_invert = OFF
set rc_smoothing = ON
set serialrx_provider = SPEK1024
set sbus_inversion = ON
set rx_spi_rf_channel_count = 0
set spektrum_sat_bind = 0
set rx_min_usec = 885
set rx_max_usec = 2115
set serialrx_halfduplex = OFF
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SDCARD
set sdcard_detect_inverted = ON
set min_throttle = 1150
set max_throttle = 1850
set min_command = 1000
set motor_pwm_rate = 400
set motor_pwm_protocol = STANDARD
set failsafe_delay = 5
set failsafe_recovery_delay = 5
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_throttle_low_delay = 100
set failsafe_procedure = RTH
set failsafe_stick_threshold = 50
set failsafe_fw_roll_angle = -200
set failsafe_fw_pitch_angle = 100
set failsafe_fw_yaw_rate = -45
set failsafe_min_distance = 0
set failsafe_min_distance_procedure = DROP
set align_board_roll = 0
set align_board_pitch = 20
set align_board_yaw = 0
set gimbal_mode = NORMAL
set battery_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set current_meter_scale = 400
set current_meter_offset = 0
set multiwii_current_meter_output = OFF
set current_meter_type = ADC
set yaw_motor_direction = 1
set yaw_jump_prevention_limit = 200
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lpf_hz = 20
set flaperon_throw_offset = 200
set tri_unarmed_servo = ON
set reboot_character = 82
set imu_dcm_kp = 2500
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 10000
set imu_dcm_ki_mag = 0
set small_angle = 25
set fixed_wing_auto_arm = OFF
set disarm_kill_switch = ON
set auto_disarm_delay = 5
set gps_provider = UBLOX
set gps_sbas_mode = WAAS
set gps_dyn_model = AIR_1G
set gps_auto_config = ON
set gps_auto_baud = ON
set gps_min_sats = 6
set deadband = 5
set yaw_deadband = 5
set pos_hold_deadband = 20
set alt_hold_deadband = 50
set 3d_deadband_throttle = 50
set fw_autotune_overshoot_time = 100
set fw_autotune_undershoot_time = 200
set fw_autotune_threshold = 50
set fw_autotune_ff_to_p_gain = 10
set fw_autotune_ff_to_i_tc = 600
set inav_auto_mag_decl = ON
set inav_gravity_cal_tolerance = 5
set inav_use_gps_velned = ON
set inav_gps_delay = 200
set inav_reset_altitude = FIRST_ARM
set inav_max_surface_altitude = 200
set inav_w_z_surface_p =  3.500
set inav_w_z_surface_v =  6.100
set inav_w_z_baro_p =  0.350
set inav_w_z_gps_p =  0.200
set inav_w_z_gps_v =  0.500
set inav_w_xy_gps_p =  1.000
set inav_w_xy_gps_v =  2.000
set inav_w_z_res_v =  0.500
set inav_w_xy_res_v =  0.500
set inav_w_acc_bias =  0.010
set inav_max_eph_epv =  1000.000
set inav_baro_epv =  100.000
set nav_disarm_on_landing = OFF
set nav_use_midthr_for_althold = OFF
set nav_extra_arming_safety = ON
set nav_user_control_mode = ATTI
set nav_position_timeout = 5
set nav_wp_radius = 100
set nav_wp_safe_distance = 10000
set nav_auto_speed = 1250
set nav_auto_climb_rate = 500
set nav_manual_speed = 1250
set nav_manual_climb_rate = 200
set nav_landing_speed = 200
set nav_land_slowdown_minalt = 500
set nav_land_slowdown_maxalt = 2000
set nav_emerg_landing_speed = 500
set nav_min_rth_distance = 500
set nav_rth_climb_first = OFF
set nav_rth_climb_ignore_emerg = OFF
set nav_rth_tail_first = OFF
set nav_rth_allow_landing = FS_ONLY
set nav_rth_alt_mode = AT_LEAST
set nav_rth_abort_threshold = 50000
set nav_rth_altitude = 1000
set nav_mc_bank_angle = 30
set nav_mc_hover_thr = 1500
set nav_mc_auto_disarm_delay = 2000
set nav_fw_cruise_thr = 1300
set nav_fw_min_thr = 1100
set nav_fw_max_thr = 1900
set nav_fw_bank_angle = 30
set nav_fw_climb_angle = 20
set nav_fw_dive_angle = 15
set nav_fw_pitch2thr = 10
set nav_fw_loiter_radius = 3000
set nav_fw_land_dive_angle = 2
set nav_fw_launch_velocity = 300
set nav_fw_launch_accel = 1863
set nav_fw_launch_max_angle = 45
set nav_fw_launch_detect_time = 40
set nav_fw_launch_thr = 1700
set nav_fw_launch_idle_thr = 1000
set nav_fw_launch_motor_delay = 500
set nav_fw_launch_spinup_time = 100
set nav_fw_launch_timeout = 5000
set nav_fw_launch_climb_angle = 18
set telemetry_switch = OFF
set telemetry_inversion = OFF
set frsky_default_latitude =  0.000
set frsky_default_longitude =  0.000
set frsky_coordinates_format = 0
set frsky_unit = METRIC
set frsky_vfas_precision = 0
set frsky_vfas_cell_voltage = OFF
set hott_alarm_sound_interval = 5
set smartport_uart_unidir = OFF
set smartport_fuel_percent = OFF
set ibus_telemetry_type = 0
set ltm_update_rate = NORMAL
set ledstrip_visual_beeper = OFF
set osd_video_system = 2
set osd_row_shiftdown = 0
set osd_units = METRIC
set osd_rssi_alarm = 20
set osd_cap_alarm = 0
set osd_time_alarm = 30
set osd_alt_alarm = 200
set osd_artificial_horizon_reverse_roll = OFF
set osd_crosshairs_style = DEFAULT
set osd_left_sidebar_scroll = NONE
set osd_right_sidebar_scroll = NONE
set osd_sidebar_scroll_arrows = OFF
set osd_main_voltage_pos = 2433
set osd_rssi_pos = 2101
set osd_flytimer_pos = 311
set osd_ontime_pos = 279
set osd_flymode_pos = 2349
set osd_throttle_pos = 65
set osd_vtx_channel_pos = 200
set osd_crosshairs_pos = 0
set osd_artificial_horizon_pos = 2248
set osd_current_draw_pos = 2450
set osd_mah_drawn_pos = 2439
set osd_craft_name_pos = 84
set osd_gps_speed_pos = 2137
set osd_gps_sats_pos = 2105
set osd_gps_lon_pos = 402
set osd_gps_lat_pos = 384
set osd_home_dir_pos = 2094
set osd_home_dist_pos = 2113
set osd_altitude_pos = 2081
set osd_vario_pos = 183
set osd_vario_num_pos = 248
set osd_pid_roll_pos = 322
set osd_pid_pitch_pos = 354
set osd_pid_yaw_pos = 386
set osd_power_pos = 47
set osd_air_speed_pos = 163
set osd_ontime_flytime_pos = 2455
set osd_rtc_time_pos = 407
set osd_messages_pos = 2369
set osd_gps_hdop_pos = 320
set osd_main_cell_voltage_pos = 44
set osd_throttle_auto_thr_pos = 2401
set osd_heading_graph_pos = 82
set osd_efficiency_pos = 2444
set i2c_speed = 400KHZ
set debug_mode = NONE
set acc_task_frequency = 500
set attitude_task_frequency = 250
set async_mode = NONE
set throttle_tilt_comp_str = 0
set input_filtering_mode = OFF
set mode_range_logic_operator = OR
set stats = OFF
set stats_total_time = 0
set stats_total_dist = 0
set tz_offset = 0
# profile
profile 1
set mc_p_pitch = 40
set mc_i_pitch = 30
set mc_d_pitch = 23
set mc_p_roll = 40
set mc_i_roll = 30
set mc_d_roll = 23
set mc_p_yaw = 85
set mc_i_yaw = 45
set mc_d_yaw = 0
set mc_p_level = 20
set mc_i_level = 15
set mc_d_level = 75
set fw_p_pitch = 14
set fw_i_pitch = 29
set fw_ff_pitch = 136
set fw_p_roll = 10
set fw_i_roll = 22
set fw_ff_roll = 100
set fw_p_yaw = 11
set fw_i_yaw = 24
set fw_ff_yaw = 111
set fw_p_level = 20
set fw_i_level = 5
set fw_d_level = 75
set max_angle_inclination_rll = 300
set max_angle_inclination_pit = 300
set dterm_lpf_hz = 40
set yaw_lpf_hz = 30
set dterm_setpoint_weight =  0.000
set fw_iterm_throw_limit = 165
set fw_reference_airspeed =  1000.000
set fw_turn_assist_yaw_gain =  1.000
set dterm_notch_hz = 0
set dterm_notch_cutoff = 1
set pidsum_limit = 500
set yaw_p_limit = 300
set iterm_ignore_threshold = 200
set yaw_iterm_ignore_threshold = 50
set rate_accel_limit_roll_pitch = 0
set rate_accel_limit_yaw = 10000
set heading_hold_rate_limit = 90
set nav_mc_pos_z_p = 50
set nav_mc_pos_z_i = 0
set nav_mc_pos_z_d = 0
set nav_mc_vel_z_p = 100
set nav_mc_vel_z_i = 50
set nav_mc_vel_z_d = 10
set nav_mc_pos_xy_p = 65
set nav_mc_pos_xy_i = 120
set nav_mc_pos_xy_d = 10
set nav_mc_vel_xy_p = 180
set nav_mc_vel_xy_i = 15
set nav_mc_vel_xy_d = 100
set nav_fw_pos_z_p = 50
set nav_fw_pos_z_i = 0
set nav_fw_pos_z_d = 0
set nav_fw_pos_xy_p = 75
set nav_fw_pos_xy_i = 5
set nav_fw_pos_xy_d = 8
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 20
set pitch_rate = 20
set yaw_rate = 20
set tpa_rate = 0
set tpa_breakpoint = 1500
QuadCrash
Der DUMP von @Sibi ist für iNav 1.8.x. Für 2.0 RC5 sind Anpassungen notwendig ... also eher nicht ungeprüft verwenden. Grundsätzlich kann man sich schon an anderen Konfigurationen orientieren, nur ist meist die Hardware (Elektronik, Ruderanlenkung etc.) nicht identisch und da ist es eher schwierig eine andere Config zu übernehmen. Besser ist m.M. die Default-Config zu nehmen und ggfs. via AutoTune zu optimieren, wenn im Manual-Modus alles so weit ok ist.
RCLogger
Oben
