BG gimbal from BRoland / rendered image & milling cutter drawing
broland
I designed a gimbal for GOPRO, and similar compact cameras.
Made of 1.5mm thick fiberglass sheets, motors RC-Timer BC2826, or equal size.
The prototype is now under manufacturing, testing, assembly photos soon.
If you have a program you can check the plan, please do it. (I can be wrong too :rolleyes:).
Vertical adjustment is +- 10mm, horizontally is +- 15mm .
The plans are free to download, to be used also for commercial purposes!
Important: damage caused by uncontrolled manufacturing can not be held responsible!
If you are satisfied with my work, he built (or checked out), and you like it, and can do, please donate!
Anhang anzeigen bg_BRoland.dxf
Sehr Schöne Konstruktion ***** Fünf Sterne! :)
Allerdings lässt die Nick Achse keinen Schwerpunktausgleich zu ;)
Das sollte unbedingt geändert werden!
broland
The top three hole thinking, in which the lock can not be set?
If so, i calculate the center of gravity, and modifies can be set.
