2x neue Zippy Lipos. Nur für die Fotos aus der Verpackung geholt. Noch nie geladen. Je 42,- inkl. Versand nach DE oder 80,- für beide inkl. Versand nach DE.
1x Naze32, hab inzwischen 3 der Kleinen, mehr als Copter... . 42,- inkl. Versand nach DE.
Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today!
Spec.
Capacity: 8000mAh
Voltage: 3S1P / 3 Cell / 11.1v
Discharge: 30C Constant / 40C Burst
Weight: 644g (including wire, plug & case)
Dimensions: 169x69x27mm
Balance Plug: JST-XH
Discharge plug: 5.5mm Bullet-connector (without housing)
Spec.
Capacity: 8000mAh
Mini Flight Controller 「なぜ」 (pronounced "Naze").
- 36x36mm
- 6 grams (no headers, 8 grams with)
- Invensense MPU3050 3-axis gyro
- Analog ADXL345 digital accelerometer
- Honeywell HMC5883L digital compass
- Bosch-Sensortec BMP085 pressure sensor
- Flexible motor outputs, support various airframe types -
Quad/Hexa/Tri/Bi/Y4/Y6/Octo/Camera Gimbal. (Default is Quad-X)
- Up to 8 ch RC input - supports standard receivers or CPPM receiver. RC breakout cable included
- Battery voltage monitoring
- Modern 32-bit processor running at 3.3V/72MHz.
- Onboard USB for setup and configuration
- LEDs so bright, they will blind you
MultiWii-based configuration software for easy setup
Designed for use with small indoor or small to mid-sized outdoor multirotor craft, or as a standalone camera stabilizer, the Naze32 flight control is simple to setup, with configuration based on the familiar “MultiWii” software.
- 36x36mm
