wegen Projektaufgabe verkaufe ich hier 8 x 30A "Hobbypower" Regler mit SimonK Firmware. Ich fliege die Teile in meinem X-520 und bin absolut zufrieden. Die Regler sind neu, original verpackt und noch nie im Einsatz gewesen.
Hier die Specs:
Soldered with 3pcs 3.5mm gold female plug, very convenient to connect motor.
Highest efficiency 100% N-FET design.
No low voltage cutoff, because any cutoff in a multirotor = crash.
No over temp cutoff, because any cutoff in a multirotor = crash.
Super high refresh rate, no buffering of the input signal, resulting in more than 490Hz response rate.
16KHz motor frequency, giving fastest response of the motor, and quietest operation as well (no 8KHz squeal).
Super simple, foolproof operation! Nothing to program other than the throttle range.
ESC Specs:
Cont. current: 30A
Max. current: 35A
Input Voltage: 2-4S lipo / 4-12 cell Ni-MH/Ni-Cd
BEC: 5V 2A (Linear mode)
Size: 55x26x8mm (length 145mm including power cable)
Weight: ~22g
Für alle 8 Regler hätte ich gerne 54,99€ inkl. Versand per DHL
Hier die Specs:
ESC Specs:
Cont. current: 30A
Max. current: 35A
Weight: ~22g
