Indoor-Quad Einzelteilverkauf, Teil 2
[hr][/hr]
Biete zwei Sensoren für den APM:
3DR Optical Flow v1.0
MaxBotix HRLV-EZ4 Sonar
[hr][/hr]
Komplettpreis für beide Sensoren: € 59,- inkl. Versand nach DE. Zahlung per PayPal oder Überweisung.
Anfragen per PN.
Es handelt sich um einen Privatverkauf. Garantie, Gewährleistung und Rücknahme sind ausgeschlossen.
[hr][/hr]
This board comes with the ADNS3080 mouse sensor and a lens-mount assembly that can let your vehicles use some pretty cool features such as horizontal altitude hold for quads and helis, odometry and obstacle avoidance.
The HRLV-MaxSonar-EZ4 is the narrowest beam width sensor that is also the least sensitive to side objects offered in the HRLV-MaxSonar-EZ sensor line. The HRLV-MaxSonar-EZ4 is an excellent choice when only larger objects need to be detected.
Component Overview:
- Resolution of 1‑mm
- 10Hz reading rate
- Internal temperature compensation
- Virtually no sensor dead zone, objects closer than 30 cm will typically range as 30 cm
- Maximum range of 5000 mm (195 inches)
Component Overview:
- 10Hz reading rate
[hr][/hr]
Anfragen per PN.
