Hi!
Ich hab hier 3 Stück T-Motor RC Tiger MT2216 800kV V2 samt Prop-Mitnehmer abzugeben.
Montiert, jedoch nie im Einsatz gewesen.
Motorkabel gekürzt auf ~15cm
Specifications:
KV............................................................................................................800
Configu ration...............................................................................12N14P
Stator Diameter................................................................................22mm
Stator Length....................................................................................16mm
Shaft Diameter...................................................................................4mm
Motor Dimensions(Dia.*Len)...........................................Φ27.5×34mm
Weight (g)...............................................................................................75g
ldle current(10)@10v(A).....................................................................0.3A
No.of Cells(Lipo).................................................................................3-4S
Max Continuous current(A)180S.......................................................18A
Max Continuous Power(W)180S....................................................260W
Max. efficiency current..........................................................(5-15A)>80%
internal resistance.........................................................................175mΩ
Pro Stück 20 EUR
alle 3 zusammen 50 EUR
Gruß aus Wien,
Christian
Specifications:
Pro Stück 20 EUR
Gruß aus Wien,
Christian
