Hallo!
Hab hier 2x das 433Mhz Radio Telemetry Kit von rctimer.com abzugeben.
Jedes Set besteht aus jeweils einem Air-Module und einem Ground-Module.
Hier nochmal die Facts:
·Small size and light weight
·Available in 433MHz variants
·Receiver sensitivity to -121 dBm
·Transmit power up to 20dBm (100mW)
·Transparent serial link
·Air data rates up to 250kbps
·MAVLink protocol framing and status reporting
·Frequency hopping spread spectrum (FHSS)
·Adaptive time division multiplexing (TDM)
·Support for LBT and AFA
·Configurable duty cycle
·Built in error correcting code (can correct up to 25% data bit errors)
·Demonstrated range of several kilometers with a small omni antenna
·Can be used with a bi-directional amplifier for even more range
·Open source firmware
·AT commands for radio configuration
·RT commands for remote radio configuration
·Adaptive flow control when used with APM
·Based on the HopeRF HM-TRP radio module, featuring an SiLabs Si1000 RF microcontroller.
Datasheets of HM-TRP module: http://www.hoperf.com/upload/rf_app/HM-TRP.pdf
Documentation: http://code.google.com/p/ardupilot-mega/wiki/3DRadio
Radio Configurator(Air module need a USB-UART tool like FTDI to configure): http://www.rctimer.com/download/RCTIMER_Radio.rar
Board schmatic:
Other
·Dimension: Air / Ground module(no include SMA connector) : 17mx35mm / 17mmx59mm
·Weight: Air / Ground module: 4.6g/16.8g(include cable and antenna) / 7.2g/17g(include antenna)
Package content
·Air Module( 433Mhz) x 1
·Ground Module(433Mhz) x 1
·UART 4Pin cable for Air module 300mm x1
·2.5dbi Antenna for two module x2
Ein Set ist noch komplett original verpackt, das andere Set ist zwar ausgepackt aber unbenutzt. Hatte vor es zu verwenden und hab daher beide Teile in Schrumpfschlauch eingepackt.
Je Set 42 EUR inkl. Versand nach AT/DE.
Bezahlung per paypal möglich, Versand erfolgt am nächsten Werktag.
Gruß aus Wien,
Christian
Board schmatic:
Other
Package content
Gruß aus Wien,
Christian
