Brand: Racerstar
Item name: BR4108 600KV Brushless Motor
RPM/V: 600KV
Height: 30mm
Width: φ46.2mm
Shaft diameter: φ4.0mm
Motor mount hole size: 4-M3
Weight: 92 grams
Voltage: 4-6S
Battery: 4-6S lipo battery
Wire length: 100mm
Usage: 500 550 600 class Frame Kit
Tested with 14.8V voltage 1555CF propellers:
Load current: 23.0A
Pull: 1930g
Power: 340W
Efficiency: 5.7 (g/W)
Features:
Long life Japanese NMB ball bearings
Efficient Japanese Kawasaki stator steel
Rare earth magnets stable up to 180
Oxygen free pure commer wires
CNC machined aluminum case
Silicone wire leads
Patented balance techniques
Unique wiring method
€ 39,- inkl. Versand
RPM/V: 600KV
Height: 30mm
Width: φ46.2mm
Weight: 92 grams
Voltage: 4-6S
Wire length: 100mm
Load current: 23.0A
Pull: 1930g
Power: 340W
Features:
Silicone wire leads
