Verkaufe hier fünf Motoren;
Specs:
Kv: 1070 rpm/v
Operating Current: 0.8A ~ 9.5A
Peak Current: 9.5A
Max Power: 105W
Cell count: 3S LiPoly
Weight: 48g
Dimensions: 27 x 28mm
Shaft dia: 3.175mm
Shaft length: 13mm
Mounting hole dimensions: Front 12 x 12mm M2/Rear 16 x 19mm M3
Suggested Battery: 1300~1700mAh 3S1P
Suggested prop size: 9x4.7
Vier sind einmal in der Luft gewesen.
Der Ersatzmotor noch nie.
....für alle fünf 50 €
Specs:
Kv: 1070 rpm/v
Peak Current: 9.5A
Max Power: 105W
Weight: 48g
Shaft dia: 3.175mm
Shaft length: 13mm
