APM 2.6 LED Treiber Platine mit ULN2803 und Spannungswandler
Preis: 8,90 € incl. unvers. Versand (Warensendung) per Paypal friendly
If you choose to control the pins directly from the APM, you must choose LEDs which have a current draw lower than the maximum permissible current of the AVR chip on the APM: 40mA.
For AC3.1.5, the pinout of the APM is as follows:
A4 : AUX led
A5 : Beeper – can drive a piezo buzzer directly (see below)
A6 : GPS – will flash with no GPS lock, solid with GPS lock
A7 ~ A11 : Motor LEDs
Which LEDs are active and when they blink is somewhat configurable through the LED_MODE parameter which can be set from the Mission Planner’s CONFIG/TUNING > Standard Params > Copter LED Mode drop down.
For AC3.2, the LED_MODE parameter is removed but all the following reduced set of pins are always active:
A4 : Motor LED
A7: Arming LED
Privatverkauf: keine Garantie - keine Gewährleistung - Keine Rücknahme
Unversicherter Versand auf Risiko Käufer - ansonsten Aufschlag von 4,50 €
A4 : AUX led
A4 : Motor LED
A7: Arming LED
