VERKAUFT
Patchantenne von BG, nagelneu. Perfekt verarbeitet! Sieht sehr hochwertig aus.
8€ inkl. Briefversand oder Tausch gegen Helix/CL/SPW Antenne (auch Eigenbau) oder nützliches Kleinzeug wie Kabel etc.
Item Name: 5.8G 14DBi FPV High Gain Mini Panel Antenna
Frequency Range-MHz : 5600-5950 MHz
Gain-dBi : 14dbi
3db Vertical Beamwidth : 40 degree
3db Horizontal Beamwidth : 35degree
Impedance- : 50 ohm
Polarization : Vertical
Sidelobe suppression>=13DB
VSWR : <=1.5
front-to-back ratio:>=25DB
Maximum Power-W : 50
Connector : SMA Male
Dimensions-mm : 60X55X6
Weight : 30g
DC Grounded
High self recovery function.
Features:
- Specially designed for RC FPV,mini size,high gain,low SWR and High self recovery function with any angle.
- Distance can reach 15kM with 5.8g 1200mw VTX/RX,distance can reach pass 5km with 5.8g 600mw VTX/RX.
Gain-dBi : 14dbi
Impedance- : 50 ohm
VSWR : <=1.5
Weight : 30g
DC Grounded
Features:
