[Verkauft] OrangeRx R620 Spektrum/JR DSM2 Compatible Full Range 6Ch 2.4Ghz Receiver
ich biete euch hier einen Orange 2,4GHz 6 Kanal Empfänger an. Neu und unbenutzt!
OrangeRx R620 full range receiver w/failsafe, S.BUS and satellite port ready.
The new range of OrangeRx R620 receivers are built using original components and MCUs, and with state of the art SMT automation to ensure a quality product each and every time.
All OrangeRx receivers are QC tested before leaving the factory.
The OrangeRx will work with ANY Aircraft Spektrum/JR DSM2 2.4Ghz transmitter.
The OrangeRx R620 is only 10.2g in weight and 46x23x13mm in size with case, Great for medium/small planes & helis, right up to large scale models.
Features:
Specification:
Channels: 6
Input voltage: 3.7~7.0V
Size: 46x23x13mm with case
Weight: 10.2g with case
Vorgestellt habe ich mir 9€ + 3,50€ Versand (Großbrief per Einschreiben)
Chriss
P.S.: gerne auch im Tausch mit Wertausgleich gegen einen FrSky D8R-II plus oder D4R-II.
Features:
- Super light weight at just 10.2 grams with case.
- Compatible with DSM2 1024/2048 aircraft radio and module systems.
- Full range operation
- 6 Channels
- Compact design
- Single 140mm antenna for mounting in almost any location.
- 1 Satellite port included.
- Input voltage: 3.7~7.0V.
- 1 Port S.BUS OUT (uses BATT/BIND port) - Works with S.BUS servos and GY750.
- Failsafe: All channels to bind position at signal loss.
Specification:
Channels: 6
Chriss
