kann mir mal bitte jemand erklären wie ich die CAM Tilt Funktion einschalte?!? Das Board hat einen CAM-Pitch Ausgang (44) an dem ich einen Servo hänge.
Im Sketch habe ich folgendes eingeschaltet:
sowie
Aber am Servo kommt nix an.
Code:
/*********************** Cam Stabilisation ***********************/ /* The following lines apply only for a pitch/roll tilt stabilization system. Uncomment the first or second line to activate it */
//#define SERVO_MIX_TILT
#define SERVO_TILT
#define TILT_PITCH_MIN 1020 //servo travel min, don't set it below 1020
#define TILT_PITCH_MAX 2000 //servo travel max, max value=2000
#define TILT_PITCH_MIDDLE 1500 //servo neutral value
#define TILT_PITCH_PROP 15 //servo proportional (tied to angle) ; can be negative to invert movement
//#define TILT_PITCH_AUX_CH AUX2 //AUX channel to overwrite CAM pitch (AUX1-AUX4), comment to disable manual input and free the AUX channel
#define TILT_ROLL_MIN 1020
#define TILT_ROLL_MAX 2000
#define TILT_ROLL_MIDDLE 1500
#define TILT_ROLL_PROP 10
#define TILT_ROLL_AUX_CH AUX4 //AUX channel to overwrite CAM Roll (AUX1-AUX4), comment to disable manual input and free the AUX channel
Code:
/*********************** HW PWM Servos ***********************/
/* HW PWM Servo outputs for Arduino Mega.. moves:
Pitch = pin 44
Roll = pin 45
CamTrig = pin 46
SERVO4 = pin 11 (assigned to PPM or SPECTRUM CH9 on copter configuration)
SERVO5 = pin 12 (assigned to PPM or SPECTRUM CH10 on copter configuration)
this option disable other software PWM's for servos - only five hardware controlled servos avaliable
#define MEGA_HW_PWM_SERVOS
