4x DYS 10A ESC
Biete vier neue DYS 10A BLHeli ESCs an. Kosten bei banggood $7,58
sind alle vier neu und original verpackt.
Preis: 7€ pro stück inkl Versand
bezahlung per überweisung
http://www.banggood.com/DYS-10A-2-3S-Brushless-Multicopter-ESC-with-BLHeli-Program-p-969392.html
Description:
Brand Name: DYS
Item NO.:BL10A
Model: 10A ESC
Categories: Speed controller
Specification:
Continuous Current:10A
Burst Current(10s):15A
Battery:2-4s Lipo
Length:38mm
Width:16.4mm
Height:4.5mm
Weight:8.5g
With BLHeli Program
Without BEC
Features:
◆ Multi-rotor special program, fast throttle response;
◆ Automatically apply throttle characteristics, has a very good motor compatibility;
◆ Supports up to 500Hz refresh rate up to the throttle signal, compatible with all flight control;
◆ Introduction of new technology ultra-low resistance MOSFET, and all drivers are all N-channel tube, strong resistance to flow capacity;
◆ PCB copper thickness has special thick treated with aluminum heat sink, heat is smaller;
◆ BL ESC whole series specially designed for welding banana plugs directly on the board, reducing the wire connection to improve reliability;
Description:
Brand Name: DYS
Item NO.:BL10A
Model: 10A ESC
Specification:
Battery:2-4s Lipo
Length:38mm
Width:16.4mm
Height:4.5mm
Weight:8.5g
With BLHeli Program
Without BEC
Features:
