VERKAUFT Eachine Mini APM V3.1 Flight Controller With GPS Module
Hallo liegt bei mir nur rum,
Eachine Mini APM V3.1 Flight Controller With GPS Module (ist das 6m Gps also das bessere)
ist OVP und neu nie benutzt oder Verkabelt worden.
39€ incl. päckchengebühr
Habe auch noch das
APM 2.6 2.5 2.52 Power Module With 5.3V DC BEC für sagen wir 10€ wenn es jemand mit dazu nimmt
DESCRIPTION :
Beschreibung bei Banggood
Item Name: Eachine MINI APM V3.1 Flight Controller With GPS
Hardware version: V3.1
Dimension: 35 x 35mm
Weight : about 22g
Support mode: fixed wing,multi-rotor
Interface: 8 output, 8 way output, GPS, telemetry +OSD, I2C (for external Compass), voltage and current detection input, USB, power supply input
Features:
Function and firmware are the same as APM, can be used in fixed wing and multi-rotor.
GPS with onboard compass
8-CH output and 8-CH input
Can connect to external GPS,telemetry system and PM module
12-CH function interface
A0 - A12 interface has also been introduced in V3.1 version.
Mini APM no internal integrated compass, need customer self configuration GPS module with a compass.
Package Included:
1 x Eachine Mini APM V3.1 Flight Controller with case
1 x GPS module with compass
1 x connecting wire
