Doch..
The ESC supports 2S to 4S operation.
It supports damped light mode, overtemp protection and bootloader on input plug.
Switching speed is quite fast, although high side is slow to turn on.
Both high side and low side are Nfets.
At 2S, low voltage limiting does not work reliably.
The ESC is also known as "F-30A UBEC".
It uses the "HK_UBEC_30A_.." code.
Falsche ESC ausgewählt, oder alte Version? 13.1 nehmen.. es gibt nur Damped Light für Multirotor, für Flieger evtl. was anderes nötig als Multi?
