Internes Modul für die Dominator das gleich 3 Bänder abdeckt.
The Beta bands RX has specific demodulation to ensure 100% compatibility with the alternative band 5G8 transmitters.
Pin compatible with existing modules and works with Dominator, DominatorV2 and DominatorHD. Band selection via a 2p DIP switch on the module
NexWaveRF Beta Band modules, NEW!!!!!
Fatshark Dominator 5.8Ghz receiver module plug & play.
-90 dBi (more range)
High Pass Filtered
NexWaveRF
SMA connectror
5.8GHz video receiver module for the FatShark Dominator video glasses that works with many other brands of 5.8GHz video transmitters (Known as the "BETA" Frequencies for the NexWaveRF receiver module).
These receivers are only compatible with Boscam, Skyzone, and other similar systems that use the following "BETA" frequencies. While they are compatible with standard FatShark and ImmersionRC transmitters due to modulation differences they might not perform as well as the standard channel (Alpha) module option.
Receiver Frequency Module DIP switch (0-1): 5865, 5845, 5825, 5805, 5785, 5765, 5545, 5725MHz
Receiver Frequency Module DIP switch (1-0): 5733, 5752, 5771, 5790, 5809, 5828, 5847, 5866MHz
Receiver Frequency Module DIP switch (1-1): 5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945MHz
Zustand: War nur zum testen einmal kurz ausgepackt.
Preis: 35 eur (inkl. Versand)
High Pass Filtered
NexWaveRF
SMA connectror
