D
Frsky RX8R PRO
An upgraded version based on the RX8R receiver, it has all the same features including redundancy. The Pro version has higher precision and lower latency. It’s deviation of PWM is reduced to 0.5us, and the delay of PWM output is 9ms less than that of the X8R in high speed mode. A feature that deserves mention is the decreased effect of interference caused by the ignition process.
Support redundancy function
Smart Port enabled and support telemetry data transmission
Higher precision deviation of PWM
Lower latency on the PWM output
Strong anti-interference performance
SPECIFICATION
Dimension: 25mm*26.6mm*14.2mm (L*W*H)
Weight: 12.1g
Numbers of Channels: 16CH(1~8CH PWM or 9~16CH PWM from conventional channel outputs, 1~16CH from SBUS)
Operating Voltage Range: 3.5V~10V
Operating Current: 100mA@5V
Operating Range: full range
Compatibility: D16/D8 mode
Servo Frame Rate: 9ms (HS—High Speed Mode)/18ms (FS—Normal Speed Mode)
SPECIFICATION
Weight: 12.1g
