Hobbyking hat jetzt auch einen Groundrecorder:
http://www.hobbyking.com/hobbyking/store/__19557__5_8G_Pocket_FPV_Ground_Station_with_DVR.html
Produktbeschreibung:
Pocket sized yet packed with features this 5.8ghz mini FPV ground station will become an indispensable companion while Sloping FPV off a clif with an ocean view on a Sunday afternoon or capturing the next killer FPV video set to go Viral on YouTube!
The built in 2.4inch LCD screen can display video in real time so your flying buddies can see all the action without needing to pass around your FPV goggles. Play back mode allows you to review recordings on the spot to re-live nail biting moments instantly!
Compatible with our 5.8ghz Goggles this unit works completely independently and is powered by its own internal battery. Featuring Video in and out this unit can also be used as a DVR for any other FPV setup running channels not compatible with the unit (Your existing system will require video out)
With vibration feed back for a tactile experience, Remote control power on and recording, USB interface, folding antenna and an easy to use menu system this is one of the most feature packed FPV accessories we have come across this year.
Specs:
Video size: VGA(640x480) QVGA(320x240)
Video Format: MPEG-4, Single audio
Memory: Built-in Memory (About 59MB) Support MicroSD (TF) Card up to 16GB
Wireless Receiving: 8 Channel, 5.8Ghz
LCD: 2.4" 480x234 dot TFT Screen
AV output: Signal Audio Channel, Video output
AV input: Signal Audio Channel, Video input
USB Interference: USB 2.0
Battery: Rechargeable Li-battery 3.7V
Power adapter input: AC 100V-240V 5-/60Hz Output: DC5V/1A
Power consumption: 1.2W
Speaker: Built-in Single audio
Working Temperature: 0-40 Centigrade
Storage Temperature: -40 Centigrade -70 Centigrade
Weight: 95g
Included:
Mini DVR
Li-rechargeable battery
Remote Control
USB Cable
AV Cable
Power adapter
Channels
5.8G : 5705,5865,5665,5645,5885,5905,5925,5945MHZ
Mich würde interresieren ob jemand das ding kennt und ob das ding etwas taugt?
Specs:
Weight: 95g
Included:
Mini DVR
Remote Control
USB Cable
AV Cable
Power adapter
Channels
