Ich verkaufe hier ein neues UHF-System (1x TX + 2x RX) von HawkEYE.
Das System kam bei mir leider nie zum Einsatz und ist somit NEU.
Technische Daten:
HawkEYE DTF UHF DeluxeTX Taranis/JR/turnigy compatible(DJRTX)
Item specifics
Use:
Vehicles & Remote Control Toys
is_customized:
Yes
Brand Name:
HawkEYE
Material:
Plastic
RC Parts & Accs:
Radio Systems
Model Number:
433mhz
JR/Turnigy/Taranis compatible:
DeluxeTX
Product Description
- Plugs right into your JR compatible radio! 2S or 3S lipo required
- Integrated mini-USB port for easy configuration
- Compatible with Taranis FrSky and SmartPort telemetry
- Lowpass RF filter for reduced interference
- Antenna comes out the top!
- 2.1mm barrel jack to provide radio battery power to your goggles
This radio can cause problems with some controllers, which can show up as ‘ghost’ button presses. This can be prevented by: using a very high quality antenna; using a directional antenna; and/or applying shielding to your radio.
HawkEYE UHF system 433MHz 9-channel long range receiver
Item specifics
RC Parts & Accs:
Radio Systems
Material:
Plastic
Brand Name:
HawkEYE
Model Number:
433mhz
is_customized:
Yes
Use:
6channel long range receiver
Product Description
Comes with openlrsNG software version 3.4.0. Compatible with all transmitters that use openlrsNG. Full-range receiver.
Features:
Lowpass input filter to reduce out-of-band interference
PPM output up to 16 channels (enable in menu)
Completely user-settable frequency selections: 413MHz up to 453MHz
Up to 24 hopping channels, user-settable
Custom pin mapping
Adjust settings and bind wirelessly, without digging it out of your aircraft
Can also be used as a transmitter
-121dBm rated sensitivity
54x24mm size with pins and SMA
around 9 grams with servo pins and SMA connector
Preis: 100€
Technische Daten:
Item specifics
Use:
is_customized:
Yes
Brand Name:
HawkEYE
Material:
Plastic
RC Parts & Accs:
Radio Systems
Model Number:
433mhz
DeluxeTX
Product Description
Item specifics
RC Parts & Accs:
Radio Systems
Material:
Plastic
Brand Name:
HawkEYE
Model Number:
433mhz
is_customized:
Yes
Use:
Product Description
Features:
Custom pin mapping
Preis: 100€
