HobbyKing® KK-Mini Multi-Rotor Flight Control Board 36x36mm (30.5x30.5mm)
Mister-XL
Das ist das Kleine
Specs:
Size: 36x36x11.5mm (mounting holes 30.5x30.5mm)
Weight: 8.6g
IC: Atmega644 PA
Gyro/Acc: 6050MPU InvenSense Inc.
Auto-level: Yes
Input Voltage: 4.8-6.0V
AVR interface: standard 6 pin.
Signal from Receiver: 1520us (5 channels)
Signal to ESC: 1520us
LCD size: 24*18mm
Mini buttons size:Four 3.3*4.2mm
Voltage sensor: One red positive pin header for.
Input rail: Single row 2.54mm pitch pin header for input Signal
Customer self-update function.
Satellite input use Satellite-to-CPPM converter (#24524) at throttle channel(need steveis SW)
Sbus input use SBUS-to-CPPM converter (#52185) at throttle channell(need steveis SW)
