VERKAUFT HobbyKing Tiny OSD NEU
todibi
Ich verkaufe hier ein neues Tiny OSD. Es war eigentlich für ein neues Modell gedacht aber aus Zeitgründen hat sich das zerschlagen.
The HobbyKing Tiny OSD III unit is a quick and easy way to add an array of on screen information to your FPV system. With GPS coordinates, ground speed, voltmeter, altitude, amp draw, consumed mAh and a return to home arrow this OSD unit will make a great addition to any FPV system.
*Note: New version now includes an upgraded 80A current (amp draw) sensor.
Features:
• Ground Speed
• Altitude
• Latitude and Longitude
• GPS Signal
• RSSI
• Battery Voltage
• Current Draw
• Consumed mAh
• Distance
• Return to Home Arrow
• Supports NTSC and PAL TV signal
Specs:
Weight: 41g (total)
Size:
Main board 41mmx24mmx11mm
GPS Module 35mmx27mmx9mm
Amp Sensor 58mmx25mmx9mm
Working Voltage: OSD 7.4V-12V / GPS Module 5V
Preis: 80€
