Verkaufe
iFlight Alpha A65 65mm Tiny Whoop with SucceX F4 1S 5A AIO Whoop Board/XING w/VTX/199C 0802 - 22000KV motor
Anschluss: 1S oder 1S HV
Voll funktionstüchtig mit viel Zubehör:
- Empfänger Radiomaster R81 SBUS
- 18 Akkus davon 10 gebraucht – 8 Stück Neu
Alle 1S HV (4,35V) 300 mAh
- Original Anschluss Kabel ESC auf PH2.0
- Adapterkabel Molex auf PH2.0
- 3 Satz neue Propeller
- Tasche
- 1 Ersatzrahmen
- 2 Ersatzhauben
- USB Winkeladapter
- Ersatzschrauben mit Schraubenzieher
- Original Kabelset
- Lipo Bag
Preis: 120 Euro VB
Original Produktbeschreibung:
Let's welcome the iFlight Alpha series, a new way to fly FPV. This Alpha A65 is an even smaller size 65mm light weight 24.5g whoop. Stuffed with our newest electronic components and technology, this thing will guarantee loads of hours practice or racing across the smallest spaces. This is what we came up with to combine flight time efficiency with sufficient power.
FEATURES:
24.5 grams (without battery)
Butter smooth XING 0802 22000KV (more torque and efficiency with longer flight times)
Ducts to protect the sensitive environment or yourself
Pre-tuned with smooth cinematic settings
Alpha A65 w/800TVL 150° camera BNF Specs:
SucceX F4 1S 5A AIO Whoop Board w/VTX
XING 0802 22000KV FPV Micro Motor
Wheelbase: 65mm
Body size: 46*46mm
Ducted propeller size: 31mm
FC pattern: 25.5*25.5mm
Weight: 24.5g (without battery)
PRE-TUNED & PRE-SETUP:
- Don't worry about tuning, we did that for you already! A basic PID- and Filter tuning was applied for a great flight experience!
To restore lost tunes or updates, please check our linked article on "Firmware/Factory Dumps"
- Angle-Mode (self balancing level mode) is enabled by default to make sure your first flight doesn't end in a mess!
Please check our linked article on "How to disable Angle-Mode, activate Acro-Mode
Alpha A65 w/800TVL 150° Camera Quad BNF Included Components and Parts
Prebuilt and tested Quadcopter
1x Alpha 65mm Frame
1x 800TVL 150° Camera
1x SucceX F4 1S 5A AIO Whoop Board (MPU6000) w/VTX
1x Whip antenna
Props HQ 31mmx3 1mm
FC // SucceX F4 1S 5A AIO Whoop Board (LINK)
Mounting pattern: 25.5*25.5mm/φ3mm (half-hole)
Connector:Micro-USB
Weight: 5.4g (with power cable, vtx, and vtx antenna)
MCU:STM32F411
Gyro:MPU6000
Blackbox:no
BEC output:5V 1.2A
INA pad:n uart2
Barometer:no
FC Firmware:MatekF411RX
ESC Firmware:O-H-30 BLS 16.8
ESC // 5A
Current: 5A continuous and peak 6A
Current scale: 400
Input:1S
Signal Support: Dshot,Oneshot,Multishot
Current sensor:yes
BLHeli:BLHeli-S
ESC Telemetry:no
FPV cam:
Power DC: 5V
Net weight: 1.6g
800TVL 150°
VTX:
Input voltage: 5V
Channels: 48CH
Power: PIT/25/50mW
Connector:UFL/IPEX
- Tasche
- 1 Ersatzrahmen
- 2 Ersatzhauben
- USB Winkeladapter
- Original Kabelset
- Lipo Bag
Preis: 120 Euro VB
FEATURES:
Wheelbase: 65mm
Body size: 46*46mm
1x Alpha 65mm Frame
1x Whip antenna
Props HQ 31mmx3 1mm
Connector:Micro-USB
MCU:STM32F411
Gyro:MPU6000
Blackbox:no
BEC output:5V 1.2A
INA pad:n uart2
Barometer:no
ESC // 5A
Current scale: 400
Input:1S
Current sensor:yes
BLHeli:BLHeli-S
ESC Telemetry:no
FPV cam:
Power DC: 5V
Net weight: 1.6g
800TVL 150°
VTX:
Input voltage: 5V
Channels: 48CH
Power: PIT/25/50mW
Connector:UFL/IPEX
