VERKAUFT ImmersionRC EZUHF Transmitter + Diversity Receiver
todibi
Ich verkaufe hier ein SET "EZUHF Transmitter und einen Diversity Receiver".
Das Set beinhaltet alle Antennen sowie ein 12V Anschlussstecker für den Transmitter und ein Futaba Anschlusskabel.
Preis: 230€uro + 7 Euro Versand.
Und hier noch ein paar technische Daten:
Transmitter:
The Immersion EzUHF Transmitter offers reliable long-range FPV/UAV model control with an output of up to 600mW. Over one year of development, testing and refinement was invested in the EzUHF line of products.
Robust FHSS link
The robust FHSS (Frequency Hopping, Spread Spectrum) link hops to a new frequency every 22ms. This increases the robustness of the link, and makes it immune to most sources of interference.
A GFSK (Gaussian Frequency Shift Keying) modulation scheme reduces unwanted harmonics, normally present with traditional FSK modulation.
Power Boost Switch
A transmitter-mounted switch controls the power level, allowing an additional boost to get out of trouble.
USB Port
A standard Mini-A USB port provides a connection to a PC, for firmware upgrades, and system diagnostics and configuration. There is no external hardware required for firmware updating.
Head-tracker Compatibility
Twin 4-pin Mini-Din connectors provide the connection to the R/C Transmitter, and also to a compatible head-tracker. Even radios which didn’t previously support head-tracking can now be used.
Compatibility
With its flexible power source options, and wide PPM input range, the EzUHF Tx is compatible with most R/C transmitters available on the market today.
A standard DC power jack allows power to be supplied directly to the module, useful in remote-mounting applications, where long cable runs may be required.
Licensing
The EzUHF transmitter requires a license to operate in most countries. In the USA, or the EU, an Amateur Radio license is required.
Features:
• Reliable FHSS Link (Frequency Hopping, Spread Spectrum)
• 433MHz/70cm Ham band operation
• GFSK modulation
• 600mW (~28dBm) output power
• Direct head-tracker input, adding head-tracker compatibility to most radios
• Power switch, ability to boost power when at long range
• Standard SMA antenna connector, compatibility with 70cm antennas
• Flexible buffered, AC-coupled, PPM input, ensures compatibility with 3.3V ~ 9.6V PPM levels
• Standard USB port (Mini-A) for firmware upgrades, and system configuration
• Single push-button learning of failsafe positions
• Binding function, which allows binding Single Tx->Rx, Multi Tx->Rx, and Single Tx->Multi Rx
• Works with 8 channel and 4 channel EzUHF receivers
• Power sourced directly from the R/C Transmitter (Futaba style), or optional DC power jack
• Built in receiver for future expansion
• Custom extruded brushed aluminum enclosure
Specs:
Power Requirements:
9~12V
Dimensions: 85x74x23mm
Weight: 118g
Diversity Receiver:
The EzUHF 8 channel diversity receiver is a compact 8CH receiver for use with the ImmersionRC EzUHF system. It can provide long range control of your FPV model with the robust interference rejection that diversity antennas provide.
Compact Long-Range R/C Receiver
Ideal companion to the EzUHF transmitter. Sensitive receiver, with twin antenna inputs, in a diversity configuration. Fits the most slender of glider fuselages.
Interference Rejection
Each antenna input contains a 7-section ceramic low-pass filter, which silences interference from nearby high-power video transmitters on 900/1.2/2.4/… bands. Attenuation at 900MHz is > 40dB, at 2.4GHz > 75dB, right at the antenna input.
Mikrokopter Compatibility
Programmable MK mode, emits raw PPM on a chosen channel. The EzUHF Rx is an ideal receiver to use on Mikrokopters used for longer-range flights.
The ceramic filtering is a huge benefit on a small MK frame, which has a Video Tx antenna nearby.
EzLink connection to an EzOSD
No more guessing! the EzLink cable connects the EzUHF to an EzOSD on-screen display. All critical parameters are sent to the OSD, which displays them live on the display and downlinks them along with the antenna-tracking telemetry.
A ground-based EzAntennaTracker displays the parameters on its LCD display, and the ImmersionPlayer application plots them on its Google-Earth™ overlay.
* Why ‘Bi-directional ready’?: The EzUHF Transmitter is a full transceiver, i.e. it includes both transmitter, and receiver hardware. The 8 Channel receiver is also a transceiver, so both are capable of bi-directional communications. Firmware to take advantage of these capabilities will available in the near future, both are field-upgradable using a std. USB cable.
EzUHF Long-Range R/C Receiver, 8 Channel Compact, Sensitive, Diversity…
Features:
• -112dBm Sensitivity
• Bi-directional ready * (contains onboard transmitter)
• Diversity Antenna configuration
• Ceramic filtered inputs, eliminates nearby high-power video Tx interference
• Mikrokopter mode, emits PPM on a chosen channel
• Vehicle mode, couples two chosen channels (ideal for coupling steering servos on monster trucks)
• USB Connection for easy firmware upgrades, and advanced configuration
• EzLink connection to a EzOSD, providing in-flight display, and telemetry down-linked parameters:
-RSSI Ant. 1, Ant 2
-Frequency Error
-SNR for each freq. bin
-Link Quality
• Standard SMA antenna connectors, compatibility with standard 433/70cm band antennas
• 8 standard servo connectors
• Failsafe, preset by button on the EzUHF transmitter
Specs:
Power Requirements: 4.8~6V, 35mA (Rx mode), 95mA (Tx mode)
Dimensions: 70x28x18mm
Weight: 19g
todibi
Das EZUHF ist TOP in Ordnung, verkaufe es weil ich zu selten "long range Flüge" mache. Und außerdem nervt mich die Umsteckerei immer weil ich mehrere Modelle habe und für jedes Modell ein ImmersionRC Empfänger zu kaufen finde ich zu teuer.
