Jumper Naze32&OSD Flight Control Support Baseflight Cleanflight With LED Taillights
Mister-XL
Das sieht doch mal vielversprechend aus.
Flight Control Introduction
JUMPER production NAZE32 flight control, built-in three-axis gyroscope, three-axis accelerometer, a barometer, and the integration of supporting OSD, set aside the I2C interface and the GPS interface enables all functions NAZE32 of. The integrated OSD can show attitude, voltage, altitude, direction, location. Based on open source, the autopilot can brush baseflight, cleanflight other open source compatible firmware, the factory default brush into cleanflight firmware (programmable to match the WS2812 taillight use). This flight control has been supporting an eight WS2812 LED
taillights, make flying more fun.
Description:
Brand Name: JUMPER
Item Name: NAZE32&OSD Flight Control32-bit ARM micro processor running at 3.3V / 8MHZ.
With gyro, extended reservation position for accelerometer, barometer.
Manual mode, Angle mode, Horizon mode, Altitude hold mode (this mode is available in advanced version)
Support Quad-,Tri-,Hex- ,various multirotors.
Flexible RC input: standard, CPPM (PPM SUM)
Battery voltage monitoring and low alarm.
Micro-USB: Flashing firmware & adjusting parameter
Parameters adjustment interface: Baseflight-Configuration.
Features:
With SBUS Conversion line,support for SBUS function.
Cleanflight & Baseflight supported.
Unique wire-to-board connectors, wiring easier!
Thin and light design, reducing overall weight saving mounting space!
Adapting high quality electronic components & high precision SMT.
lysie
Wenn doch die chinesen nur mal aufhören könnten den alten käse rauszubringen. Wozu der extra s bus inverter? Warum das nicht gleich auf der Platine umsetzen? Warum nicht gleich ein F3 Prozessor? Kosten meines wissen inzwischen genau soviel. In den letzten paar Monaten sind jetzt bestimmt schon 5 neue F1 Naze clones rausgebracht worden... Schon veraltet bevor es über die Ladentheke geht.
