JussiH GoPro 3 Gimbal
FireN
trägt sonst keine Brille!
oh ja... sieht sau gut aus :)
Boarder
Soll es :
we aim to launch the controller and IMU at 99 euro or less. With a little luck we should have the controller and motors available in 2-3 weeks.
GoPro Gimbal for HeroHD and GoPro2 will be launched first. Also of course version for GoPro3. We dont have an ETA on those, since it depends on how fast our metalworking factory can produce them for us. We are shooting for them to be available inside 3-4 weeks, but its not a promise.
GoPro version is 268 grams with camera and controller. GoPro3 version will be slightly lighter.
We are currently designing gimbal for Compact and System cameras like HX9, Nex 5/5N/7 and EOS M.
Later will come versions for DSLR and Camcorders like CX730 and CX760.
http://www.rcgroups.com/forums/showthread.php?t=1815204
Zlui
Weiß jemand, was später zu kaufen sein wird? Nur Gimbal, Gimbal + Motoren, oder Gimbal + Motoren + Steuerung?
Alveran
Ich schätze mal das das gesamte Packet angeboten wird..
Alles andere wäre ja nicht funktionstüchtig ^^
Boarder
My personal opinion about preorders is that it is an unserious way of doing business, usually associated with substandard products beeing rushed to market without proper development and quality control.
But we may just begin a controller preorder run on monday, since all aspects are locked in now and we have 100 percent confindence in the product we are going to offer.
I can say that the "motherload" of controllers will arrive late next week, so we should be ready to fill orders very soon. We did have some problems with delivery of the IMU´s, but they have been solved and IMU´s are enroute to us now.
The Viacopter gimbal goes into production on monday - and it will thus not only be "Danish Design", it will also be "Made in Denmark", so we can get them fast in highest possible quality and have complete control over production.
Final version (we went through 4 prototypes before we was satisfied with it) was completed yesterday and is working perfectly with the new 2208 motors. Performance is even better than version 1, that was used to make the test video on page 1. And our new 2208 motors is working incredibly good - better than any we wound ourselves.
We invested a lot of time and effort into making it perfect, instead of rushing it to market and taking peoples money for a product that is "less than perfect" - we leave it up to others to do that!.
The result is a controller that is better made, uses the best available components and is tested properly before release. And a gimbal we are 100 percent satisfied with - we strive for perfection and we made sure to get it!
If you are very impatient, there is other deals out there, but I am confident that none of them was made with the attention to detail and support that is associated with all Viacopter/Flyduino/E-copter products - and IMHO that will be well worth the extra waiting time.
Von Jussi.... Könnte bald losgehen.... Auch bei flyduino ???
FireN
steht ja dabei, kanns nur hoffen :)
marco19752
.....geht in die Luft
Hier mal Infos zum Gimbal:
Edit: Bei diesem Post handelt es sich um das Angebot von E-Copter.
PLease find below first of all a few informations about the various versions of the gimbals, prices and deposit amounts, you will find at the end of email the details for the deposit process:
Luxury Edition:
It will come in a small plastic case with pre-cut foam, and the content will be the following:
- Aluminum 7075 gimbal cage and arms
- Pro version of the gimbal motors (x2)
- Viacopter / E-Copter / Flyduino control board
- USB cable
- Sensor board 6050
- Horizontal mount (dampened)
- Vertical mount (dampened), fitting Droidworx CX4 V2 or similar frames ( easy to adapt on any frames, in fact)
- Small adapter for the DJI Phantom mount ( 2x M3 at 40mm distance)
- Enclosure for control board when mounting on standard frames
- Cables
- Manual
Price is 499 Euro Including 19.6% VAT, or 417.22 Euro Ex. VAT.
VAT will be applied or not depending on the shipping destination and / or valid VAT registration number. If you order outside the European Community you are entitled to buy without VAT. If you buy inside th European community and do not have a valid VAT number and associated shipping adress, then VAT is due.
The requested deposit is 300 euro per set to validate the order. We accept full payment in advance if the customer wishes so but it is NOT necessary. We will send the paypent requests before shipping for the remaining amount.
For all the first batch customers, shiping is free, worldwide. We are able to offer this as we have negociate a special deal with DHL, and we estimate it is normal to do a little something for the Luxury Edition customers in return of your trust in our product :)
DIY Gimbal mechanics:
The DIY Gimbal Mechanics version is G10 version based on the Cyllika version of the Gimbal, manufactured with full authorisation of Cyllika. The pre production samples have been validated and we made small changes to make the build easier. DIY gimbal mechanics kit comes with all little hardware necessary to build the gimbal ( carbon tube 5mm , plastic spacers, plastic screws, ball bearings, dampeners, tie wraps).
The DIY version has to be mounted on 2x 5mm carbon tubes.
Price is 59 euro Including VAT 19.6%, which is 49.33 Euro Ex. VAT.
Requested deposit is 30 Euro per set.
We clearly made this DIY version because we had lot of requests, and we do believe it's possible to deliver quality at friendly price. The composites are cut in China in an Industrial company who supply us since many years now and we are more than satisfied in the quality.
Controller Board:
The Controller board comes with a 6050 sensor and wiring.
Price is 110 Euro including 19.6% VAT,* which is 91.97 Euro Ex. VAT.
Requested deposit is 45 euro per controller.
If you wished a controller + "Pro" or " DIY" motors, please wait before making a deposit that we update with delays informations ( see below in motors description for explanations) .
"Pro" motors:
The "Pro" edition of the motors, manufactured in Czech Republic by our associate Lubos Chatval ( FreeAir) , are 30.5mm diameter with a 6mm stator thickness. They are wound with 0.16 mm wire.
At the present time, we do not take deposits or pre orders on these motors as we will have just enough on the first batch to supply with the Luxury Gimbals, DIY Gimbal and Viacopter also, and we wait for more informations for the additional magnet order we have launched to make more motors. We will be able to give news about this within one week or 10 days.
The price will be around 40 euro per unit,* including 19.6% VAT, to be confirmed.
"DIY" motors:
For these, our partner Viacotper found a really good source and is happy with the final results. We are talking with him to propose these motors as we would have made them more or less in the same location in China ( there are not may companies offering decent winding quality for 0.16mm wounding...). We will give the final information within one week or so about these.
The price is meant to be under 20 euro / pcs :)
