Multiwii 2_1 Fehlermeldung beim Sketch
Toastertyphoon
toastet typhoons
->Nanowii Problem <-
Heyho,
ich muss den Sketch auf mein Nanowii neu aufspielen ...
Doch wenn ich den 2.1 Sketch (.ino) öffne und just for Fun auf Überprüfen klicke, kommen schon Fehler obwohl ich noch garnichts in dem neuen Sketch geändert habe.
"InitOutput" was not declared in this Scope
PHP:
MultiWii_2_1.cpp: In function 'void setup()':
MultiWii_2_1:508: error: 'initOutput' was not declared in this scope
MultiWii_2_1.cpp: In function 'void loop()':
MultiWii_2_1:925: error: 'computeIMU' was not declared in this scope
MultiWii_2_1:1010: error: 'writeServos' was not declared in this scope
MultiWii_2_1:1011: error: 'writeMotors' was not declared in this scope
PHP:
MultiWiiCopter by Alexandre Dubus
www.multiwii.com
July  2012     V2.1
 This program is free software: you can redistribute it and/or modify
 it under the terms of the GNU General Public License as published by
 the Free Software Foundation, either version 3 of the License, or
 any later version. see <http://www.gnu.org/licenses/>
#include <avr/io.h>
#include "config.h"
#include "def.h"
#include <avr/pgmspace.h>
#define  VERSION  210
/*********** RC alias *****************/
#define ROLL       0
#define PITCH      1
#define YAW        2
#define THROTTLE   3
#define AUX1       4
#define AUX2       5
#define AUX3       6
#define AUX4       7
#define PIDALT     3
#define PIDPOS     4
#define PIDPOSR    5
#define PIDNAVR    6
#define PIDLEVEL   7
#define PIDMAG     8
#define PIDVEL     9 // not used currently
#define BOXACC       0
#define BOXBARO      1
#define BOXMAG       2
#define BOXCAMSTAB   3
#define BOXCAMTRIG   4
#define BOXARM       5
#define BOXGPSHOME   6
#define BOXGPSHOLD   7
#define BOXPASSTHRU  8
#define BOXHEADFREE  9
#define BOXBEEPERON  10
#define BOXLEDMAX    11 // we want maximum illumination
#define BOXLLIGHTS   12 // enable landing lights at any altitude
#define BOXHEADADJ   13 // acquire heading for HEADFREE mode
#define PIDITEMS 10
#define CHECKBOXITEMS 14
const char boxnames[] PROGMEM = // names for dynamic generation of config GUI
  "ACC;"
  "BARO;"
  "MAG;"
  "CAMSTAB;"
  "CAMTRIG;"
  "ARM;"
  "GPS HOME;"
  "GPS HOLD;"
  "PASSTHRU;"
  "HEADFREE;"
  "BEEPER;"
  "LEDMAX;"
  "LLIGHTS;"
  "HEADADJ;"
const char pidnames[] PROGMEM =
  "ROLL;"
  "PITCH;"
  "YAW;"
  "ALT;"
  "Pos;"
  "PosR;"
  "NavR;"
  "LEVEL;"
  "MAG;"
  "VEL;"
static uint32_t currentTime = 0;
static uint16_t previousTime = 0;
static uint16_t cycleTime = 0;     // this is the number in micro second to achieve a full loop, it can differ a little and is taken into account in the PID loop
static uint16_t calibratingA = 0;  // the calibration is done in the main loop. Calibrating decreases at each cycle down to 0, then we enter in a normal mode.
static uint16_t calibratingG;
static uint16_t acc_1G;             // this is the 1G measured acceleration
static int16_t  acc_25deg;
static int16_t  headFreeModeHold;
static int16_t  gyroADC[3],accADC[3],accSmooth[3],magADC[3];
static int16_t  heading,magHold;
static uint8_t  vbat;               // battery voltage in 0.1V steps
static uint8_t  rcOptions[CHECKBOXITEMS];
static int32_t  BaroAlt;
static int32_t  EstAlt;             // in cm
static int16_t  BaroPID = 0;
static int32_t  AltHold;
static int16_t  errorAltitudeI = 0;
#if defined(BUZZER)
  static uint8_t  toggleBeep = 0;
#endif
#if defined(ARMEDTIMEWARNING)
  static uint32_t  ArmedTimeWarningMicroSeconds = 0;
#endif
static int16_t  debug[4];
static int16_t  sonarAlt; //to think about the unit
struct flags_struct {
  uint8_t OK_TO_ARM :1 ;
  uint8_t ARMED :1 ;
  uint8_t I2C_INIT_DONE :1 ; // For i2c gps we have to now when i2c init is done, so we can update parameters to the i2cgps from eeprom (at startup it is done in setup())
  uint8_t ACC_CALIBRATED :1 ;
  uint8_t NUNCHUKDATA :1 ;
  uint8_t ACC_MODE :1 ;
  uint8_t MAG_MODE :1 ;
  uint8_t BARO_MODE :1 ;
  uint8_t GPS_HOME_MODE :1 ;
  uint8_t GPS_HOLD_MODE :1 ;
  uint8_t HEADFREE_MODE :1 ;
  uint8_t PASSTHRU_MODE :1 ;
  uint8_t GPS_FIX :1 ;
  uint8_t GPS_FIX_HOME :1 ;
  uint8_t SMALL_ANGLES_25 :1 ;
  uint8_t CALIBRATE_MAG :1 ;
} f;
//for log
#if defined(LOG_VALUES) || defined(LCD_TELEMETRY)
  static uint16_t cycleTimeMax = 0;       // highest ever cycle timen
  static uint16_t cycleTimeMin = 65535;   // lowest ever cycle timen
  static uint16_t powerMax = 0;           // highest ever current
  static uint32_t armedTime = 0;
  static int32_t  BAROaltStart = 0;       // offset value from powerup
  static int32_t    BAROaltMax = 0;            // maximum value
#endif
static int16_t  i2c_errors_count = 0;
static int16_t  annex650_overrun_count = 0;
//Automatic ACC Offset Calibration
#if defined(INFLIGHT_ACC_CALIBRATION)
  static uint16_t InflightcalibratingA = 0;
  static int16_t AccInflightCalibrationArmed;
  static uint16_t AccInflightCalibrationMeasurementDone = 0;
  static uint16_t AccInflightCalibrationSavetoEEProm = 0;
  static uint16_t AccInflightCalibrationActive = 0;
#endif
// power meter
#if defined(POWERMETER)
#define PMOTOR_SUM 8                     // index into pMeter[] for sum
  static uint32_t pMeter[PMOTOR_SUM + 1];  // we use [0:7] for eight motors,one extra for sum
  static uint8_t pMeterV;                  // dummy to satisfy the paramStruct logic in ConfigurationLoop()
  static uint32_t pAlarm;                  // we scale the eeprom value from [0:255] to this value we can directly compare to the sum in pMeter[6]
  static uint16_t powerValue = 0;          // last known current
#endif
static uint16_t intPowerMeterSum, intPowerTrigger1;
// telemetry
#if defined(LCD_TELEMETRY)
  static uint8_t telemetry = 0;
  static uint8_t telemetry_auto = 0;
#endif
// rc functions
#define MINCHECK 1100
#define MAXCHECK 1900
static int16_t failsafeEvents = 0;
volatile int16_t failsafeCnt = 0;
static int16_t rcData[8];          // interval [1000;2000]
static int16_t rcCommand[4];       // interval [1000;2000] for THROTTLE and [-500;+500] for ROLL/PITCH/YAW
static int16_t lookupPitchRollRC[6];// lookup table for expo & RC rate PITCH+ROLL
static int16_t lookupThrottleRC[11];// lookup table for expo & mid THROTTLE
volatile uint8_t rcFrameComplete; // for serial rc receiver Spektrum
#if defined(OPENLRSv2MULTI)
  static uint8_t pot_P,pot_I; // OpenLRS onboard potentiometers for P and I trim or other usages
#endif
// gyro+acc IMU
static int16_t gyroData[3] = {0,0,0};
static int16_t gyroZero[3] = {0,0,0};
static int16_t angle[2]    = {0,0};  // absolute angle inclination in multiple of 0.1 degree    180 deg = 1800
// motor and servo functions
static int16_t axisPID[3];
static int16_t motor[NUMBER_MOTOR];
#if defined(SERVO)
  static int16_t servo[8] = {1500,1500,1500,1500,1500,1500,1500,1500};
#endif
// EEPROM Layout definition
static uint8_t dynP8[3], dynD8[3];
static struct {
  uint8_t checkNewConf;
  uint8_t P8[PIDITEMS], I8[PIDITEMS], D8[PIDITEMS];
  uint8_t rcRate8;
  uint8_t rcExpo8;
  uint8_t rollPitchRate;
  uint8_t yawRate;
  uint8_t dynThrPID;
  uint8_t thrMid8;
  uint8_t thrExpo8;
  int16_t accZero[3];
  int16_t magZero[3];
  int16_t angleTrim[2];
  uint16_t activate[CHECKBOXITEMS];
  uint8_t powerTrigger1;
  #ifdef FLYING_WING
    uint16_t wing_left_mid;
    uint16_t wing_right_mid;
  #endif
  #ifdef TRI
    uint16_t tri_yaw_middle;
  #endif
  #if defined HELICOPTER || defined(AIRPLANE)|| defined(SINGLECOPTER)|| defined(DUALCOPTER)
    int16_t servoTrim[8];
  #endif
  #if defined(GYRO_SMOOTHING)
    uint8_t Smoothing[3];
  #endif
} conf;
// GPS common variables
  static int32_t  GPS_coord[2];
  static int32_t  GPS_home[2];
  static int32_t  GPS_hold[2];
  static uint8_t  GPS_numSat;
  static uint16_t GPS_distanceToHome;                          // distance to home in meters
  static int16_t  GPS_directionToHome;                         // direction to home in degrees
  static uint16_t GPS_altitude,GPS_speed;                      // altitude in 0.1m and speed in 0.1m/s
  static uint8_t  GPS_update = 0;                              // it's a binary toogle to distinct a GPS position update
  static int16_t  GPS_angle[2] = { 0, 0};                      // it's the angles that must be applied for GPS correction
  static uint16_t GPS_ground_course = 0;                       // degrees*10
  static uint8_t  GPS_Present = 0;                             // Checksum from Gps serial
  static uint8_t  GPS_Enable  = 0;
  #define LAT  0
  #define LON  1
  // The desired bank towards North (Positive) or South (Negative) : latitude
  // The desired bank towards East (Positive) or West (Negative)   : longitude
  static int16_t  nav[2];
  static int16_t  nav_rated[2];    //Adding a rate controller to the navigation to make it smoother
  // default POSHOLD control gains
  #define POSHOLD_P              .11
  #define POSHOLD_I              0.0
  #define POSHOLD_IMAX           20        // degrees
  #define POSHOLD_RATE_P         2.0
  #define POSHOLD_RATE_I         0.08      // Wind control
  #define POSHOLD_RATE_D         0.045     // try 2 or 3 for POSHOLD_RATE 1
  #define POSHOLD_RATE_IMAX      20        // degrees
  // default Navigation PID gains
  #define NAV_P                  1.4
  #define NAV_I                  0.20      // Wind control
  #define NAV_D                  0.08      //
  #define NAV_IMAX               20        // degrees
  // Serial GPS only variables
  //navigation mode
  #define NAV_MODE_NONE          0
  #define NAV_MODE_POSHOLD       1
  #define NAV_MODE_WP            2
  static uint8_t nav_mode = NAV_MODE_NONE;            //Navigation mode
void blinkLED(uint8_t num, uint8_t wait,uint8_t repeat) {
  uint8_t i,r;
  for (r=0;r<repeat;r++) {
    for(i=0;i<num;i++) {
      #if defined(LED_FLASHER)
        switch_led_flasher(1);
      #endif
      #if defined(LANDING_LIGHTS_DDR)
        switch_landing_lights(1);
      #endif
      LEDPIN_TOGGLE; // switch LEDPIN state
      BUZZERPIN_ON;
      delay(wait);
      BUZZERPIN_OFF;
        switch_led_flasher(0);
      #endif
        switch_landing_lights(0);
      #endif
    delay(60);
void annexCode() { // this code is excetuted at each loop and won't interfere with control loop if it lasts less than 650 microseconds
  static uint32_t calibratedAccTime;
  uint16_t tmp,tmp2;
  #if defined(BUZZER)
    static uint8_t  buzzerFreq;         // delay between buzzer ring
  #endif
  uint8_t axis,prop1,prop2;
  #define BREAKPOINT 1500
  // PITCH & ROLL only dynamic PID adjustemnt,  depending on throttle value
  if   (rcData[THROTTLE]<BREAKPOINT) {
    prop2 = 100;
  } else {
    if (rcData[THROTTLE]<2000) {
      prop2 = 100 - (uint16_t)conf.dynThrPID*(rcData[THROTTLE]-BREAKPOINT)/(2000-BREAKPOINT);
    } else {
      prop2 = 100 - conf.dynThrPID;
  for(axis=0;axis<3;axis++) {
    tmp = min(abs(rcData[axis]-MIDRC),500);
    #if defined(DEADBAND)
      if (tmp>DEADBAND) { tmp -= DEADBAND; }
      else { tmp=0; }
    #endif
    if(axis!=2) { //ROLL & PITCH
      tmp2 = tmp/100;
      rcCommand[axis] = lookupPitchRollRC[tmp2] + (tmp-tmp2*100) * (lookupPitchRollRC[tmp2+1]-lookupPitchRollRC[tmp2]) / 100;
      prop1 = 100-(uint16_t)conf.rollPitchRate*tmp/500;
      prop1 = (uint16_t)prop1*prop2/100;
    } else {      // YAW
      rcCommand[axis] = tmp;
      prop1 = 100-(uint16_t)conf.yawRate*tmp/500;
    dynP8[axis] = (uint16_t)conf.P8[axis]*prop1/100;
    dynD8[axis] = (uint16_t)conf.D8[axis]*prop1/100;
    if (rcData[axis]<MIDRC) rcCommand[axis] = -rcCommand[axis];
  tmp = constrain(rcData[THROTTLE],MINCHECK,2000);
  tmp = (uint32_t)(tmp-MINCHECK)*1000/(2000-MINCHECK); // [MINCHECK;2000] -> [0;1000]
  tmp2 = tmp/100;
  rcCommand[THROTTLE] = lookupThrottleRC[tmp2] + (tmp-tmp2*100) * (lookupThrottleRC[tmp2+1]-lookupThrottleRC[tmp2]) / 100; // [0;1000] -> expo -> [MINTHROTTLE;MAXTHROTTLE]
  if(f.HEADFREE_MODE) { //to optimize
    float radDiff = (heading - headFreeModeHold) * 0.0174533f; // where PI/180 ~= 0.0174533
    float cosDiff = cos(radDiff);
    float sinDiff = sin(radDiff);
    int16_t rcCommand_PITCH = rcCommand[PITCH]*cosDiff + rcCommand[ROLL]*sinDiff;
    rcCommand[ROLL] =  rcCommand[ROLL]*cosDiff - rcCommand[PITCH]*sinDiff;
    rcCommand[PITCH] = rcCommand_PITCH;
  #if defined(POWERMETER_HARD)
    uint16_t pMeterRaw;               // used for current reading
    static uint16_t psensorTimer = 0;
    if (! (++psensorTimer % PSENSORFREQ)) {
      pMeterRaw =  analogRead(PSENSORPIN);
      powerValue = ( PSENSORNULL > pMeterRaw ? PSENSORNULL - pMeterRaw : pMeterRaw - PSENSORNULL); // do not use abs(), it would induce implicit cast to uint and overrun
      if ( powerValue < 333) {  // only accept reasonable values. 333 is empirical
      #ifdef LCD_TELEMETRY
        if (powerValue > powerMax) powerMax = powerValue;
      #endif
      } else {
        powerValue = 333;
      pMeter[PMOTOR_SUM] += (uint32_t) powerValue;
  #endif
  #if defined(VBAT)
    static uint8_t vbatTimer = 0;
    static uint8_t ind = 0;
    uint16_t vbatRaw = 0;
    static uint16_t vbatRawArray[8];
    if (! (++vbatTimer % VBATFREQ)) {
        vbatRawArray[(ind++)%8] = analogRead(V_BATPIN);
        for (uint8_t i=0;i<8;i++) vbatRaw += vbatRawArray[i];
        vbat = vbatRaw / (VBATSCALE/2);                  // result is Vbatt in 0.1V steps
    if ( ( (vbat>VBATLEVEL1_3S)
                         && ( (pMeter[PMOTOR_SUM] < pAlarm) || (pAlarm == 0) )
    #endif
                       )  || (NO_VBAT>vbat)                              ) // ToLuSe
    {                                          // VBAT ok AND powermeter ok, buzzer off
      buzzerFreq = 0;
    } else if (pMeter[PMOTOR_SUM] > pAlarm) {                             // sound alarm for powermeter
      buzzerFreq = 4;
    #endif
    } else if (vbat>VBATLEVEL2_3S) buzzerFreq = 1;
    else if (vbat>VBATLEVEL3_3S)   buzzerFreq = 2;
    else                           buzzerFreq = 4;
  #endif
  #if defined(BUZZER)
    buzzer(buzzerFreq); // external buzzer routine that handles buzzer events globally now
  #endif
  if ( (calibratingA>0 && ACC ) || (calibratingG>0) ) { // Calibration phasis
    LEDPIN_TOGGLE;
  } else {
    if (f.ACC_CALIBRATED) {LEDPIN_OFF;}
    if (f.ARMED) {LEDPIN_ON;}
  #if defined(LED_RING)
    static uint32_t LEDTime;
    if ( currentTime > LEDTime ) {
      LEDTime = currentTime + 50000;
      i2CLedRingState();
  #endif
    auto_switch_led_flasher();
  #endif
  if ( currentTime > calibratedAccTime ) {
    if (! f.SMALL_ANGLES_25) {
      // the multi uses ACC and is not calibrated or is too much inclinated
      f.ACC_CALIBRATED = 0;
      LEDPIN_TOGGLE;
      calibratedAccTime = currentTime + 500000;
    } else {
      f.ACC_CALIBRATED = 1;
  #if defined(GPS_PROMINI)
    if(GPS_Enable == 0) {serialCom();}
  #else
    serialCom();
  #endif
    intPowerMeterSum = (pMeter[PMOTOR_SUM]/PLEVELDIV);
    intPowerTrigger1 = conf.powerTrigger1 * PLEVELSCALE;
  #endif
  #ifdef LCD_TELEMETRY_AUTO
    static char telemetryAutoSequence []  = LCD_TELEMETRY_AUTO;
    static uint8_t telemetryAutoIndex = 0;
    static uint16_t telemetryAutoTimer = 0;
    if ( (telemetry_auto) && (! (++telemetryAutoTimer % LCD_TELEMETRY_AUTO_FREQ) )  ){
      telemetry = telemetryAutoSequence[++telemetryAutoIndex % strlen(telemetryAutoSequence)];
      LCDclear(); // make sure to clear away remnants
  #endif
    static uint16_t telemetryTimer = 0;
    if (! (++telemetryTimer % LCD_TELEMETRY_FREQ)) {
      #if (LCD_TELEMETRY_DEBUG+0 > 0)
        telemetry = LCD_TELEMETRY_DEBUG;
      #endif
      if (telemetry) lcd_telemetry();
  #endif
  #if GPS & defined(GPS_LED_INDICATOR)
    static uint32_t GPSLEDTime;
    if ( currentTime > GPSLEDTime && (GPS_numSat >= 5)) {
      GPSLEDTime = currentTime + 150000;
      LEDPIN_TOGGLE;
  #endif
  #if defined(LOG_VALUES) && (LOG_VALUES == 2)
    if (cycleTime > cycleTimeMax) cycleTimeMax = cycleTime; // remember highscore
    if (cycleTime < cycleTimeMin) cycleTimeMin = cycleTime; // remember lowscore
  #endif
    if (f.ARMED) armedTime += (uint32_t)cycleTime;
    #if BARO
      if (!f.ARMED) {
        BAROaltStart = BaroAlt;
        BAROaltMax = BaroAlt;
      } else {
        if (BaroAlt > BAROaltMax) BAROaltMax = BaroAlt;
    #endif
  #endif
void setup() {
  #if !defined(GPS_PROMINI)
    SerialOpen(0,SERIAL_COM_SPEED);
  #endif
  LEDPIN_PINMODE;
  POWERPIN_PINMODE;
  BUZZERPIN_PINMODE;
  STABLEPIN_PINMODE;
  POWERPIN_OFF;
  initOutput();
  readEEPROM();
  checkFirstTime();
  configureReceiver();
    initOpenLRS();
  #endif
  initSensors();
  #if defined(I2C_GPS) || defined(GPS_SERIAL) || defined(GPS_FROM_OSD)
    GPS_set_pids();
  #endif
  previousTime = micros();
  #if defined(GIMBAL)
   calibratingA = 400;
  #endif
  calibratingG = 400;
    for(uint8_t i=0;i<=PMOTOR_SUM;i++)
      pMeter[i]=0;
  #endif
    ArmedTimeWarningMicroSeconds = (ARMEDTIMEWARNING *1000000);
  #endif
  #if defined(GPS_SERIAL)
    SerialOpen(GPS_SERIAL,GPS_BAUD);
    delay(400);
    for(uint8_t i=0;i<=5;i++){
      GPS_NewData();
      LEDPIN_ON
      delay(20);
      LEDPIN_OFF
      delay(80);
    if(!GPS_Present){
      SerialEnd(GPS_SERIAL);
      GPS_Present = 1;
    #endif
    GPS_Enable = GPS_Present;
  #endif
  #if defined(I2C_GPS) || defined(TINY_GPS) || defined(GPS_FROM_OSD)
   GPS_Enable = 1;
  #endif
  #if defined(LCD_ETPP) || defined(LCD_LCD03) || defined(OLED_I2C_128x64)
    initLCD();
  #endif
  #ifdef LCD_TELEMETRY_DEBUG
    telemetry_auto = 1;
  #endif
  #ifdef LCD_CONF_DEBUG
    configurationLoop();
  #endif
  #ifdef LANDING_LIGHTS_DDR
    init_landing_lights();
  #endif
  ADCSRA |= _BV(ADPS2) ; ADCSRA &= ~_BV(ADPS1); ADCSRA &= ~_BV(ADPS0); // this speeds up analogRead without loosing too much resolution: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1208715493/11
    init_led_flasher();
    led_flasher_set_sequence(LED_FLASHER_SEQUENCE);
  #endif
  f.SMALL_ANGLES_25=1; // important for gyro only conf
// ******** Main Loop *********
void loop () {
  static uint8_t rcDelayCommand; // this indicates the number of time (multiple of RC measurement at 50Hz) the sticks must be maintained to run or switch off motors
  uint8_t axis,i;
  int16_t error,errorAngle;
  int16_t delta,deltaSum;
  int16_t PTerm,ITerm,DTerm;
  static int16_t lastGyro[3] = {0,0,0};
  static int16_t delta1[3],delta2[3];
  static int16_t errorGyroI[3] = {0,0,0};
  static int16_t errorAngleI[2] = {0,0};
  static uint32_t rcTime  = 0;
  static int16_t initialThrottleHold;
  #ifdef LCD_TELEMETRY_STEP
    static char telemetryStepSequence []  = LCD_TELEMETRY_STEP;
    static uint8_t telemetryStepIndex = 0;
  #endif
  #if defined(SPEKTRUM)
    if (rcFrameComplete) computeRC();
  #endif
    Read_OpenLRS_RC();
  #endif
  #define RC_FREQ 50
  if (currentTime > rcTime ) { // 50Hz
    rcTime = currentTime + 20000;
    computeRC();
    // Failsafe routine - added by MIS
    #if defined(FAILSAFE)
      if ( failsafeCnt > (5*FAILSAVE_DELAY) && f.ARMED) {                  // Stabilize, and set Throttle to specified level
        for(i=0; i<3; i++) rcData[i] = MIDRC;                               // after specified guard time after RC signal is lost (in 0.1sec)
        rcData[THROTTLE] = FAILSAVE_THROTTLE;
        if (failsafeCnt > 5*(FAILSAVE_DELAY+FAILSAVE_OFF_DELAY)) {          // Turn OFF motors after specified Time (in 0.1sec)
          f.ARMED = 0;   // This will prevent the copter to automatically rearm if failsafe shuts it down and prevents
          f.OK_TO_ARM = 0; // to restart accidentely by just reconnect to the tx - you will have to switch off first to rearm
        failsafeEvents++;
      if ( failsafeCnt > (5*FAILSAVE_DELAY) && !f.ARMED) {  //Turn of "Ok To arm to prevent the motors from spinning after repowering the RX with low throttle and aux to arm
      failsafeCnt++;
    #endif
    // end of failsave routine - next change is made with RcOptions setting
    if (rcData[THROTTLE] < MINCHECK) {
      errorGyroI[ROLL] = 0; errorGyroI[PITCH] = 0; errorGyroI[YAW] = 0;
      errorAngleI[ROLL] = 0; errorAngleI[PITCH] = 0;
      rcDelayCommand++;
      if (rcData[YAW] < MINCHECK && rcData[PITCH] < MINCHECK && !f.ARMED) {
        if (rcDelayCommand == 20) {
          calibratingG=400;
          #if GPS
            GPS_reset_home_position();
          #endif
      } else if (rcData[YAW] > MAXCHECK && rcData[PITCH] > MAXCHECK && !f.ARMED) {
          #ifdef TRI
            servo[5] = 1500; // we center the yaw servo in conf mode
            writeServos();
          #endif
          #ifdef FLYING_WING
            servo[0]  = conf.wing_left_mid;
            servo[1]  = conf.wing_right_mid;
            writeServos();
          #endif
          #ifdef AIRPLANE
            for(i = 4; i<7 ;i++) servo[i] = 1500;
            writeServos();
          #endif
          #if defined(LCD_CONF)
            configurationLoop(); // beginning LCD configuration
          #endif
        else if (!f.ARMED && rcData[YAW] < MINCHECK && rcData[PITCH] > MAXCHECK && rcData[ROLL] > MAXCHECK){
          if (rcDelayCommand == 20){
            if (AccInflightCalibrationMeasurementDone){                // trigger saving into eeprom after landing
              AccInflightCalibrationSavetoEEProm = 1;
            }else{
              AccInflightCalibrationArmed = !AccInflightCalibrationArmed;
              #if defined(BUZZER)
              if (AccInflightCalibrationArmed){
                toggleBeep = 2;
              } else {
                toggleBeep = 3;
              #endif
     #endif
      else if (conf.activate[BOXARM] > 0) {
        if ( rcOptions[BOXARM] && f.OK_TO_ARM
          && failsafeCnt <= 1
        #endif
      f.ARMED = 1;
      headFreeModeHold = heading;
        } else if (f.ARMED) f.ARMED = 0;
        rcDelayCommand = 0;
      #ifdef ALLOW_ARM_DISARM_VIA_TX_YAW
      } else if ( (rcData[YAW] < MINCHECK )  && f.ARMED) {
        if (rcDelayCommand == 20) f.ARMED = 0; // rcDelayCommand = 20 => 20x20ms = 0.4s = time to wait for a specific RC command to be acknowledged
      } else if ( (rcData[YAW] > MAXCHECK ) && rcData[PITCH] < MAXCHECK && !f.ARMED && calibratingG == 0 && f.ACC_CALIBRATED) {
      f.ARMED = 1;
      #endif
      #ifdef ALLOW_ARM_DISARM_VIA_TX_ROLL
      } else if ( (rcData[ROLL] < MINCHECK)  && f.ARMED) {
      } else if ( (rcData[ROLL] > MAXCHECK) && rcData[PITCH] < MAXCHECK && !f.ARMED && calibratingG == 0 && f.ACC_CALIBRATED) {
          f.ARMED = 1;
      #endif
      } else if (rcData[ROLL] < MINCHECK && rcData[PITCH] > MAXCHECK && !f.ARMED) {
           if (telemetry_auto) {
              telemetry_auto = 0;
              telemetry = 0;
           } else
              telemetry_auto = 1;
      #endif
      } else if (rcData[ROLL] > MAXCHECK && rcData[PITCH] > MAXCHECK && !f.ARMED) {
          telemetry = telemetryStepSequence[++telemetryStepIndex % strlen(telemetryStepSequence)];
      #endif
      } else
        rcDelayCommand = 0;
    } else if (rcData[THROTTLE] > MAXCHECK && !f.ARMED) {
      if (rcData[YAW] < MINCHECK && rcData[PITCH] < MINCHECK) {        // throttle=max, yaw=left, pitch=min
        if (rcDelayCommand == 20) calibratingA=400;
        rcDelayCommand++;
      } else if (rcData[YAW] > MAXCHECK && rcData[PITCH] < MINCHECK) { // throttle=max, yaw=right, pitch=min
        if (rcDelayCommand == 20) f.CALIBRATE_MAG = 1; // MAG calibration request
        rcDelayCommand++;
      } else if (rcData[PITCH] > MAXCHECK) {
         conf.angleTrim[PITCH]+=2;writeParams(1);
           blinkLedRing();
         #endif
      } else if (rcData[PITCH] < MINCHECK) {
         conf.angleTrim[PITCH]-=2;writeParams(1);
           blinkLedRing();
         #endif
      } else if (rcData[ROLL] > MAXCHECK) {
         conf.angleTrim[ROLL]+=2;writeParams(1);
           blinkLedRing();
         #endif
      } else if (rcData[ROLL] < MINCHECK) {
         conf.angleTrim[ROLL]-=2;writeParams(1);
           blinkLedRing();
         #endif
      } else {
        rcDelayCommand = 0;
      led_flasher_autoselect_sequence();
    #endif
      if (AccInflightCalibrationArmed && f.ARMED && rcData[THROTTLE] > MINCHECK && !rcOptions[BOXARM] ){ // Copter is airborne and you are turning it off via boxarm : start measurement
        InflightcalibratingA = 50;
        AccInflightCalibrationArmed = 0;
      if (rcOptions[BOXPASSTHRU]) {      // Use the Passthru Option to activate : Passthru = TRUE Meausrement started, Land and passtrhu = 0 measurement stored
        if (!AccInflightCalibrationActive && !AccInflightCalibrationMeasurementDone){
      }else if(AccInflightCalibrationMeasurementDone && !f.ARMED){
    #endif
    uint16_t auxState = 0;
    for(i=0;i<4;i++)
      auxState |= (rcData[AUX1+i]<1300)<<(3*i) | (1300<rcData[AUX1+i] && rcData[AUX1+i]<1700)<<(3*i+1) | (rcData[AUX1+i]>1700)<<(3*i+2);
    for(i=0;i<CHECKBOXITEMS;i++)
      rcOptions[i] = (auxState & conf.activate[i])>0;
    // note: if FAILSAFE is disable, failsafeCnt > 5*FAILSAVE_DELAY is always false
    if (( rcOptions[BOXACC] || (failsafeCnt > 5*FAILSAVE_DELAY) ) && ACC ) {
      // bumpless transfer to Level mode
      if (!f.ACC_MODE) {
        f.ACC_MODE = 1;
    } else {
      // failsafe support
      f.ACC_MODE = 0;
    if (rcOptions[BOXARM] == 0) f.OK_TO_ARM = 1;
    if (f.ACC_MODE) {STABLEPIN_ON;} else {STABLEPIN_OFF;}
    #if BARO
      if (rcOptions[BOXBARO]) {
        if (!f.BARO_MODE) {
          f.BARO_MODE = 1;
          AltHold = EstAlt;
          initialThrottleHold = rcCommand[THROTTLE];
          errorAltitudeI = 0;
          BaroPID=0;
      } else {
        f.BARO_MODE = 0;
    #endif
    #if MAG
      if (rcOptions[BOXMAG]) {
        if (!f.MAG_MODE) {
          f.MAG_MODE = 1;
          magHold = heading;
      } else {
        f.MAG_MODE = 0;
      if (rcOptions[BOXHEADFREE]) {
        if (!f.HEADFREE_MODE) {
          f.HEADFREE_MODE = 1;
      } else {
        f.HEADFREE_MODE = 0;
      if (rcOptions[BOXHEADADJ]) {
        headFreeModeHold = heading; // acquire new heading
    #endif
    #if GPS
      static uint8_t GPSNavReset = 1;
      if (f.GPS_FIX && GPS_numSat >= 5 ) {
        if (!rcOptions[BOXGPSHOME] && !rcOptions[BOXGPSHOLD] )
          {    //Both boxes are unselected
            if (GPSNavReset == 0 ) {
               GPSNavReset = 1;
               GPS_I2C_command(I2C_GPS_COMMAND_STOP_NAV,0);
        if (rcOptions[BOXGPSHOME]) {
         if (!f.GPS_HOME_MODE)  {
            f.GPS_HOME_MODE = 1;
            GPSNavReset = 0;
            GPS_I2C_command(I2C_GPS_COMMAND_START_NAV,0);        //waypoint zero
        } else {
          f.GPS_HOME_MODE = 0;
        if (rcOptions[BOXGPSHOLD]) {
          if (!f.GPS_HOLD_MODE & !f.GPS_HOME_MODE) {
            f.GPS_HOLD_MODE = 1;
            GPSNavReset = 0;
            GPS_I2C_command(I2C_GPS_COMMAND_POSHOLD,0);
        } else {
          f.GPS_HOLD_MODE = 0;
      #endif
      #if defined(GPS_SERIAL) || defined(TINY_GPS) || defined(GPS_FROM_OSD)
            GPS_set_next_wp(&GPS_home[LAT],&GPS_home[LON]);
            nav_mode    = NAV_MODE_WP;
        } else {
          if (!f.GPS_HOLD_MODE) {
            GPS_hold[LAT] = GPS_coord[LAT];
            GPS_hold[LON] = GPS_coord[LON];
            GPS_set_next_wp(&GPS_hold[LAT],&GPS_hold[LON]);
            nav_mode = NAV_MODE_POSHOLD;
        } else {
      #endif
    #endif
    if (rcOptions[BOXPASSTHRU]) {f.PASSTHRU_MODE = 1;}
    else {f.PASSTHRU_MODE = 0;}
    #ifdef FIXEDWING
    #endif
  } else { // not in rc loop
    static uint8_t taskOrder=0; // never call all functions in the same loop, to avoid high delay spikes
    switch (taskOrder++ % 5) {
      case 0:
        #if MAG
          Mag_getADC();
        #endif
        break;
      case 1:
        #if BARO
          Baro_update();
        #endif
        break;
      case 2:
        #if BARO
          getEstimatedAltitude();
        #endif
        break;
      case 3:
        #if GPS
          if(GPS_Enable) GPS_NewData();
        #endif
        break;
      case 4:
        #if SONAR
          Sonar_update();debug[2] = sonarAlt;
        #endif
          auto_switch_landing_lights();
        #endif
        break;
  computeIMU();
  // Measure loop rate just afer reading the sensors
  currentTime = micros();
  cycleTime = currentTime - previousTime;
  previousTime = currentTime;
  #if MAG
    if (abs(rcCommand[YAW]) <70 && f.MAG_MODE) {
      int16_t dif = heading - magHold;
      if (dif <= - 180) dif += 360;
      if (dif >= + 180) dif -= 360;
      if ( f.SMALL_ANGLES_25 ) rcCommand[YAW] -= dif*conf.P8[PIDMAG]/30;  // 18 deg
    } else magHold = heading;
  #endif
  #if BARO
    if (f.BARO_MODE) {
      if (abs(rcCommand[THROTTLE]-initialThrottleHold)>ALT_HOLD_THROTTLE_NEUTRAL_ZONE) {
        f.BARO_MODE = 0; // so that a new althold reference is defined
      rcCommand[THROTTLE] = initialThrottleHold + BaroPID;
  #endif
  #if GPS
    if ( (!f.GPS_HOME_MODE && !f.GPS_HOLD_MODE) || !f.GPS_FIX_HOME ) {
      GPS_reset_nav(); // If GPS is not activated. Reset nav loops and all nav related parameters
    } else {
      float sin_yaw_y = sin(heading*0.0174532925f);
      float cos_yaw_x = cos(heading*0.0174532925f);
   #if defined(NAV_SLEW_RATE)
      nav_rated[LON] += constrain(wrap_18000(nav[LON]-nav_rated[LON]),-NAV_SLEW_RATE,NAV_SLEW_RATE);
      nav_rated[LAT] += constrain(wrap_18000(nav[LAT]-nav_rated[LAT]),-NAV_SLEW_RATE,NAV_SLEW_RATE);
      GPS_angle[ROLL]   = (nav_rated[LON]*cos_yaw_x - nav_rated[LAT]*sin_yaw_y) /10;
      GPS_angle[PITCH]  = (nav_rated[LON]*sin_yaw_y + nav_rated[LAT]*cos_yaw_x) /10;
   #else
      GPS_angle[ROLL]   = (nav[LON]*cos_yaw_x - nav[LAT]*sin_yaw_y) /10;
      GPS_angle[PITCH]  = (nav[LON]*sin_yaw_y + nav[LAT]*cos_yaw_x) /10;
   #endif
  #endif
  //**** PITCH & ROLL & YAW PID ****
    if (f.ACC_MODE && axis<2 ) { //LEVEL MODE
      // 50 degrees max inclination
      errorAngle = constrain(2*rcCommand[axis] + GPS_angle[axis],-500,+500) - angle[axis] + conf.angleTrim[axis]; //16 bits is ok here
      #ifdef LEVEL_PDF
        PTerm      = -(int32_t)angle[axis]*conf.P8[PIDLEVEL]/100 ;
      #else
        PTerm      = (int32_t)errorAngle*conf.P8[PIDLEVEL]/100 ;                          // 32 bits is needed for calculation: errorAngle*P8[PIDLEVEL] could exceed 32768   16 bits is ok for result
      #endif
      PTerm = constrain(PTerm,-conf.D8[PIDLEVEL]*5,+conf.D8[PIDLEVEL]*5);
      errorAngleI[axis]  = constrain(errorAngleI[axis]+errorAngle,-10000,+10000);    // WindUp     //16 bits is ok here
      ITerm              = ((int32_t)errorAngleI[axis]*conf.I8[PIDLEVEL])>>12;            // 32 bits is needed for calculation:10000*I8 could exceed 32768   16 bits is ok for result
    } else { //ACRO MODE or YAW axis
      if (abs(rcCommand[axis])<350) error =          rcCommand[axis]*10*8/conf.P8[axis] ; // 16 bits is needed for calculation: 350*10*8 = 28000      16 bits is ok for result if P8>2 (P>0.2)
                               else error = (int32_t)rcCommand[axis]*10*8/conf.P8[axis] ; // 32 bits is needed for calculation: 500*5*10*8 = 200000   16 bits is ok for result if P8>2 (P>0.2)
      error -= gyroData[axis];
      PTerm = rcCommand[axis];
      errorGyroI[axis]  = constrain(errorGyroI[axis]+error,-16000,+16000);          // WindUp   16 bits is ok here
      if (abs(gyroData[axis])>640) errorGyroI[axis] = 0;
      ITerm = (errorGyroI[axis]/125*conf.I8[axis])>>6;                                   // 16 bits is ok here 16000/125 = 128 ; 128*250 = 32000
    if (abs(gyroData[axis])<160) PTerm -=          gyroData[axis]*dynP8[axis]/10/8; // 16 bits is needed for calculation   160*200 = 32000         16 bits is ok for result
                            else PTerm -= (int32_t)gyroData[axis]*dynP8[axis]/10/8; // 32 bits is needed for calculation
    delta          = gyroData[axis] - lastGyro[axis];                               // 16 bits is ok here, the dif between 2 consecutive gyro reads is limited to 800
    lastGyro[axis] = gyroData[axis];
    deltaSum       = delta1[axis]+delta2[axis]+delta;
    delta2[axis]   = delta1[axis];
    delta1[axis]   = delta;
    if (abs(deltaSum)<640) DTerm = (deltaSum*dynD8[axis])>>5;                       // 16 bits is needed for calculation 640*50 = 32000           16 bits is ok for result
                      else DTerm = ((int32_t)deltaSum*dynD8[axis])>>5;              // 32 bits is needed for calculation
    axisPID[axis] =  PTerm + ITerm - DTerm;
  mixTable();
  writeServos();
  writeMotors();
Kann wer helfen ?
Roberto
Auf die Idee, mal die Config.h "just for Fun" einzustellen bist Du natürlich nicht gekommen. Steht ja auch nur in JEDER ANLEITUNG.
Sogar hier: http://fpv-community.de/showthread.php?2558-Quadrocopter-WiiCopter-detaillierte-Bauanleitung
Schön, dass wir jetzt auch noch das Hauptprogramm in Bunt haben.
WARNUNG!!!! BITTE NICHT DIE BETRIEBSANLEITUNG HIER LESEN: http://flyduino.net/documents/NanoWii_manual.pdf
Kann wer helfen ?
Keiner, das Problem gehört zu den ungelösten Mysterien der Mwii.
Rob
w.frischknecht
...hä?!...fpv...was?
....und täglich grüsst das Murmeltier. :D
Das Leben ist eine lose Aneinanderreihung von Wiederholungen nicht?
Roberto....ich bin mit dir.
Toastertyphoon
toastet typhoons
Und schau, es funzt ... mal wieder nicht Nachgedacht - Gelesen.
Trozdem hab ich immernoch ein Problem mit dem Nanowii Board.
Das Board erkennt die Kanäle 2-4 nichtmehr ( Reglereingang)
ledeglich Kanal 1 funzt noch.
Vor ca 1-2 Wochen hat das Board noch ordnungsgemäß funktioniert .
Ich steh aufm Schlauch
Roberto
Der Link wird Dir nichts bringen. Einen Hardwareschaden halte ich für eher unwahrscheinlich.
Hast Du schon mal das probiert:
Code:
  /********   Settings for ProMicro, Leonardo and other Atmega32u4 Boards     ***********/
    /*********************************    pin Layout     **********************************/
      /* activate this for a better pinlayout if all pins can be used => not possible on ProMicro */
      //#define A32U4ALLPINS
Rob
Butcher
Bill the Butcher
Das nanowii hast du defined im sketch?
hast du die andern regler auch richtig dran? was sagt die gui ?
Toastertyphoon
toastet typhoons
@Roberto :
Hat nichts gebracht Piepen weiter.
@Butcher :
Die anderen Regler sind richtig dran.
AUch wenn ich Regler 1 (der an Kanal 1 hängt und initalisiert) und den an Kanal 2 hänge fängt der an zu Piepen und initalisiert nicht.
Die Gui verhält sich normal, alle Sensoren reagieren und wenn ich das Gas hochjage wirds auch angezeigt.
So schauts angesteckt aus http://fpv-community.de/attachment.php?attachmentid=38966&d=1351533973
Toastertyphoon
toastet typhoons
Hehe, kann ich ja garnicht machen mit dem Kanäle tauschen, da ich ja nur 6 zur verfügung habe ;)( wenn die denn gehen sollten)
Es ist auch nicht normal dass das Nanowii in kurzer Zeit sehr Warm wird (?).
zerosight
Also bei mir ist noch kein NanoWii auch nur ansatzweise warm geworden. Allerdings klemme ich mein NanoWii auch direkt an die 5V vom Regler und nicht direkt an den LIPo. Welche Variante der Stromversorgung hast Du den verwendet? Und was siehst Du in der GUI an Kanal 2 wenn Du da das Kabel von Kanal 1 ansteckst?
