Verkaufe mein Multiwii Pro Board mit MTK GPS Modul und Bluetoothadapter.
4 mal geflogen. Wie neu.
The MultiWii PRO is a gyro/accelerometer based flight controller that is loaded with features. This version of the MultiWii supports direct connection of a GPS module (package includes MTK 3329 GPS module) allowing for ultra-precise positioning functionality. With expandability options and full programmability, this device can control just about any type of aircraft. This is the ideal flight controller for your multi-rotor aircraft.
Features:
(MultiWii PRO)
• SMD component design with Atmega2560
• ITG3205 Triple Axis Gyro
• BMA180 Accelerometer
• BMP085 Barometer
• HMC5883L Magnetometer
• Servo output for camera pitch and roll control
• Supports direct connection of GPS module (MTK 3329 GPS module included)
• On-board USB connection for programming
(MTK 3329 GPS Module)
• Based on MediaTek Single Chip Architecture.
• L1 Frequency, C/A code, 66 channels
• High Sensitivity, Up to -165dBm tracking, providing superior urban performance
• DGPS(WAAS, EGNOS, MSAS) support (optional by firmware)
• USB/UART Interface
• Supports AGPS function (Offline mode: EPO valid up to 14 days)
Specs:
(MultiWii PRO)
Mounting: Standard Mk style mounting holes 45mm X 45mm
Dimensions: 70x50x12mm
Weight: 16g
(MTK 3329 GPS module)
Position Accuracy: < 3m CEP (50%) without SA (horizontal)
Cold Start: under 35 seconds (Typical)
Warm Start: under 34 seconds (Typical)
Hot Start: under 1 second (Typical)
Power Consumption: 48mA @ acquisition, 37mA @ tracking
Shut-down current consumption: 15uA, typical
Dimensions: 30x26x7mm
Weight: 8g
Preis 50€ inkl. Versand.
Features:
(MultiWii PRO)
• BMP085 Barometer
Specs:
(MultiWii PRO)
Weight: 16g
Weight: 8g
