Hallo an die Coptergemeinde,
da ich überzeugter "Naza Jünger" geworden bin möchte ich hier ein nagelneues, ungeöffnetes Multiwii SE v2.5 Set anbieten. Hier die Beschreibung des Verkäufers:
Crius MWC MultiWii Standard V2.5 SE Flight Controller module:
1. 6 PWM input channels for standard receiver or PPM SUM receiver
2. Supported 2-axis gimbal and auto trigger controll
3. Up to 8-axis motor output
4. FTDI/UART port for upload firmware, debug, Bluetooth module or LCD display
5. I2C port for extend sensor, I2C LCD/OLED display or I2C-GPS NAV board for GPS and Sonar
6. Ultra low noise 3.3V LDO voltage regulator
7. ATMega 328P Microcontroller
8. MPU6050C 6 axis gyro/accel with Motion Processing Unit
9. HMC5883L 3-axis digital magnetometer
10. BMP085 digital pressure sensor
11. PCA9306DP1 logic level converter
12. Small size,35x35mm mounting holes
Bluetooth parameter debug module:
1. For Multiwii FC Configuration use with Android MultiWiiConfiguration
2. UART TTL socket
3. Read and Write PID
4. Setting switch for AUX1 and AUX2
5. Monitor receiver signal and FC output signal
6. Monitor All sensors and GPS signal
7. Cablibration Magnetometer and Accelerometer
8. Save and read profile
9. Baudrate : 115200
10. Module name : CRIUS_BT
11. Pair code : 0000
12. Dimension: 15mmX37.5mm
13. Height: 5mm
14. Weight:2.2g/3.9g(include cable)
15. Hole diameter: 3mm
FTDI USB-TTL:
This is a basic breakout board for the FTDI FT232RL USB to serial IC. The pinout of this board matches the FTDI cable to work with official Arduino and cloned 5V Arduino boards. It can also be used for general serial applications. The major difference with this board is that it brings out the DTR pin as opposed to the RTS pin of the FTDI cable. The DTR pin allows an Arduino target to auto-reset when a new Sketch is downloaded. This is a really nice feature to have and allows a sketch to be downloaded without having to hit the reset button. This board will auto reset any Arduino board that has the reset pin brought out to a 6-pin connector.
GPS receiver:
Standalone GPS receiver
U-blox NEO-6M GPS module
Build in 18X18mm active GPS antenna
UART TTL socket
Rechargeable battery for Backup
Dimension: 22mmX30mm
Height: 13mm
Weight:12g/14.4g(include cable)
Hole diameter: 3mm
2C-GPS NAV Module:
All GPS data available via the I2C bus to connect to 328P Multiwii FC
A LED on board show GPS 3D Fix status
2 Molex 1.25mm 4Pin socket for GPS receiver and FC
2 port for ISP and FTDI
Dimension: 20mmX30mm
Height: 5mm
Weight:2.4g/5g(include cable)
Hole diameter: 3mm
Package Including:
1x MWC V2.5 SE Flight Controller
1x I2C-GPS NAV Module
1x CN -06 GPS receiver
1x Bluetooth module
1x FTDI USB-TTL
Ich habe von dem Teil absolut keine Ahnung, also bitte keine Fragen stellen
Mein Preis war 59,00€ für alles, ich denke wenn ich hier 45,00€ inkl. Versand innerhalb Deutschland ( ohne Inseln ) aufrufe ist das fair. Also spart Euch bitte Angebote wie: für 20€ nehm ich es.........
Da ich das Ganze nicht gewerblich sondern privat mache möchte ich ausdrücklich jegliche Gewährleistung oder ein Rückgaberecht ausschließen.
Wer zuerst kommt........
Frisch
2. UART TTL socket
13. Height: 5mm
FTDI USB-TTL:
GPS receiver:
UART TTL socket
Height: 13mm
Hole diameter: 3mm
2C-GPS NAV Module:
Height: 5mm
Hole diameter: 3mm
Package Including:
1x Bluetooth module
1x FTDI USB-TTL
Frisch
