Problems with Tarot Gimbal
compiprofi
I hope, i'm right here with my question about the tarot Gimbal TL68A00.
I try to config this one without good results.
Firmwareupdate for motordriver and Gimbal are done successful.
Now i try to make settings in the menue "motor comfiguration". Like it is recommended, is select the port, open this, power the Gimbal.
The statusbar don't come over the message "Please connect the motor port!" But i did it.
I can make settings for Polar num and Power, press "write settings to flash". But when i open the window again, i only see zeros.
Also the Signal Monitor shows "0".
Do anyone have an idea?
Will i need spec. portsettings under Windows 7 /64?
Thanks very much.
