Hallo Zusammen!!!
Für mein neues Hexa-Projekt suche ich noch 6 Regler mit hoher Taktfrequenz ( 400Mhz ) oder ähnliches.
(The faster update rate of the speed controllers is what we call "TurboPWM")
Benötigt wegen Fy-91Q Dreamcatchersystem. Folgende Voraussetzungen:
Electronic Speed Control (ESC) Requirements:
1. ESCs that can handle an input signal pulse frequency over 400Hz is a must.
2. Use only ESCs that has a manually settable throttle end points. All endpoints MUST
be manually matched.
3. ESCs with Fast response rates are recommended (high and mid timing settable).
Too slow response will result in failure to maintain Quad flight stabilization and
control.
4. Do not use ESCs that lose their throttle endpoint settings at each power off (e.g.
Castle Thunderbird series).
5. Do not use ESCs that must be "armed" before you can set the throttle endpoints
(Castle Thunderbirds, Hobby King SS ESCs, etc.). With this ESC type, you must
power up all motors and go to full throttle to set the endpoints, making it
impossible to use on multirotors.
Wenn jemand noch 6 Regler übrig hätte, die diese Anforderungen erfüllen, würde ich mich
über eine PN mit Preisvorstellung freuen.
Viele Grüsse , Mike
control.
Viele Grüsse , Mike
