Hi Leute,
bin gerade dabei einen neuen Quadrocopter zu planen. Propeller werden 12x4 CF Props und ESC 20A.
Akkus werden 4S 4000mah. Mit Option auf 2x 4S 4000mah.
Bei den Motoren schwanke ich noch zwischen zwei Modellen:
T-Motor MN3510-15 KV700
Specifications:
KV.................................................................................................................700
Configu ration.....................................................................................12N14P
Stator Diameter.....................................................................................35mm
Stator Length.........................................................................................10mm
Shaft Diameter.........................................................................................4mm
Motor Dimensions(Dia.*Len).............................................Φ41.8×28.5mm
Weight (g)....................................................................................................97g
ldle current(10)@10v(A)...........................................................................0.5A
No.of Cells(Lipo).......................................................................................3-4S
Max Continuous current(A)180S..............................................................25A
Max Continuous Power(W)180S..........................................................555W
Max. efficiency current.................................................................(4-10A)>80%
internal resistance..................................................................................50mΩ
Und diesem Motor:
U3 KV700
Specifications:
KV................................................................................................................700
Configu-ration....................................................................................12N14P
Shaft Diameter........................................................................................4mm
Motor Dimension(Dia.*Len)............................................Φ41.8×30.75mm
Weight(g)....................................................................................................97g
ldle current(10)@10v(A)..........................................................................0.5A
No.of Cells(Lipo)......................................................................................3-4S
Max Continuous current(A)180S.............................................................25A
Max Continuous Power(W)180S..........................................................500W
Max. efficiency current...............................................................(4-10A)>82%
internal resistance.................................................................................50mΩ
Der Preis ist bei dem U3 Motor etwas höher, aber das ist mir erst mal egal.
Mich würde sehr interessieren, ob es Unterschiede in der Effizienz beider Motoren gibt?
Wenn ich die Werte bei 4S und 12"Props vergleiche, dann sind diese ja exakt gleich.
Könnte das ein Anzeigefehler sein?
Was meint Ihr, mit welchem Motor ich eine höhere Flugzeit erreichen könnte?
Viele Grüße
Angelo
Specifications:
Und diesem Motor:
U3 KV700
Specifications:
Viele Grüße
Angelo
