VERKAUFT Tarot T-2D Brushless Gimbal GoPro - Haurauspreis 45 EUR
chichi
Tarot T-2D Brushless Gimbal GoPro - 39 EUR
Tarot T-2D Brushless Gimbal komplett, war nie im Einsatz, zittert ab und zu. Werte einstellen oder Neue Firmware testen!
Neu 85 EUR
Jetzt 39 EUR
Keine Garantie
Support GOPRO Hero3 video auxiliary output
- Supply voltage polarity protection and voltage compensation
- Motor drive end short-circuit protection
- Custom initial pitch angle
- Sensitivity parameter adjustment and software 3D pose show thru PC Connection
- Adjustable rocker rate mode and position mode
- Supported receiver type : conventional receiver, S-BUS receiver, DSM2/DSMJ/DSMX receiver
- Support for remote devices : PPM/PCM/2.4G
- Working voltage : DC 7.4V ~ 14.8V (Recommended 12V, three lithium battery)
- Working current : 200mA-500mA (power supply voltage and the motor related)
- Working environment temperature: -15 ℃ ~ 65 ℃
- Processor: Dual 32-bit high-speed ARM core processor
- Sensor : Three axis MEMS gyroscope and MEMS accelerometers
- Maximum angular rate : 2000 ° / sec
- Maximum acceleration : 16G
- Control frequency: 2000Hz
- Motor drive frequency: 20KHz (no noise smoothing driven)
- Control accuracy : 0.1 ° (Pixel Grade)
- Control angle range : -45 ° ~ 45 ° (roll), -135 ° ~ 90 ° (tilt)
- Pose solver algorithms : PTZ dedicated brushless motor decoupled EKF algorithm
- Shooting equipment : GOPRO Hero 3
chichi
Preis ist unten. Jetzt zuschlagen.
chichi
Knaller, ... wer kann da noch wiederstehen?
chichi
reserviert bis Geldeingang
