Ich verkaufe mein fast neues 4Fach Ladegerät von Turnigy. Ich hab mir die Kabel passend für 4 S selbst gebaut.
Es lädt wunderbar und ist intuitiv zu bedienen.
Hobbyking schreibt dazu:
70€ incl. Versand
Bei Interesse einfach eine Mail schreiben.
Turnigy 4x6S can charge four batteries packs simultaneously!
A quality designed charger with accurate balancing and a familiar, intuitive menu system.
The Turnigy 4x6 is equipped with 4 high accuracy microprocessors to charge each battery individually. Its efficient cooling system ensures safe operation throughout the charge cycle.
With the Turnigy 4x6 you are able to balance charge a lipoly pack on Port-1 while series charging a LiFePo4 or NiMH battery on Port-2. All ports work independently of each other.
Specification:
Operating voltage range: DC 11~15V
Power source: 12V DC (car battery) / AC mains PSU (>200Watts)
Cell count : 1-15 Ni-xx / 1-6 Li-xx / 1-10 Lead acid cells (2~20V)
Current drain for balancing li-xx: 335mA
Charge termination Ni-xx: Automatic, negative Delta Peak method
Charge termination Lead acid & Li-xx: Automatic, voltage dependent, CC-CV process
Maximum Charge Current per port: 6A
High velocity heatsink exhaust fan.
Specification:
70€ incl. Versand
