VERKAUFT Turnigy Integrated PCB Micro-Quad V2 (Black) (KIT)
[verkauft] Turnigy Integrated PCB Micro-Quad V2 (Black) (KIT)
habe hier noch einen Frame von Hobbyking. Ist nagelneu und Original verpackt.
This is the version 2 of the tiny yet brilliantly designed Micro-Quad, features a stronger integrated PCB frame and motor mount design but retains the same simplistic idea of bolting on the motors, then solder your choice of ESC directly to the frame!
An integrated power distribution system is also included making for one of the neatest electronics and lightest installs around. All mounting hardware and frame components are included in the kit. All you will require to have this little micro sized in the air is four micro motors, four 6-12Amp ESCs, a set of 5x3 Micro-quad props (2 Clock wise and 2 counter clockwise) an 800mah 2s or 3s Li-poly battery, a HobbyKing Multi-rotor control board and your own transmitter and receiver (TX/Rx).
Features:
• Light weight design.
• Integrated PCB for component installation.
• Included a full set of frame and mounting hardware.
Specs:
Flying Weight: 145g (not including RX and battery)
Width: 250mm~220mm hub to hub
Height: 85mm
Required:
4 x Multistar DT1704 or Turnigy T1811-2900kv
4 x 6-12Amp ESC
4 x 5x3 Prop (2CW & 2CCW)
1 x HobbyKing Multi-Rotor Control Board or any FC with 45 x 45 mm mounting
1 x 800Mah 2s or 3s Lipoly battery
16 x M2x8 Bolts (for motor)
16 x M2 lock nuts (for motor)
Your own transmitter and 4 channel receiver.
Würde ich für 12€ inclusive Versand als Maxibrief verkaufen. Kann auch gerne in Nordwalde (20 km nördlich von Münster) abgeholt werden.
Ich habe mit mittlerweile einen Frame selber gebaut und brauche den nicht mehr.
MfG,
Jörg
und weg ist er
