Scheinbar hängt sich die Version 3.1.0-rc5 beim Upload mit RCTIMER_CRIUS_V2 einfach auf. Woran kann das liegen.
//3.1.0-rc5 changes by hexbub 2013-11-31
// -*- tab-width: 4; Mode: C++; c-basic-offset: 4; indent-tabs-mode: nil -*-
// User specific config file. Any items listed in config.h can be overridden here.
// Select Megapirate board type:
#define MPNG_BOARD_TYPE RCTIMER_CRIUS_V2
// RCTIMER_CRIUS_V2 -- (DEFAULT!!!) Use ONLY for RCTimer CRIUS V2 board
// CRIUS_V1 -- Use this define for RCTimer CRIUS V1(1.1) board and all HobbyKing AIOP boards
// HK_RED_MULTIWII_PRO -- HobbyKing MultiWii Pro board with ITG3205 and BMA180, BMP085 sensors
// BLACK_VORTEX
// Currently not supported
#define CONFIG_SONAR DISABLED
//#define COPTER_LEDS DISABLED
// GPS port speed (Serial2) 38400 by default
#define SERIAL2_BAUD 38400
// GPS driver selection
#define GPS_PROTOCOL GPS_PROTOCOL_UBLOX
//#define GPS_PROTOCOL GPS_PROTOCOL_NONE
GPS_PROTOCOL_AUTO (Default)
GPS_PROTOCOL_NONE
GPS_PROTOCOL_NMEA
GPS_PROTOCOL_SIRF
GPS_PROTOCOL_UBLOX
GPS_PROTOCOL_IMU
GPS_PROTOCOL_MTK
GPS_PROTOCOL_HIL
GPS_PROTOCOL_MTK19
// QuadCopter selected by default
#define FRAME_CONFIG QUAD_FRAME
* options:
* QUAD_FRAME
* TRI_FRAME
* HEXA_FRAME
* Y6_FRAME
* OCTA_FRAME
* OCTA_QUAD_FRAME
* HELI_FRAME
#define FRAME_ORIENTATION X_FRAME
// uncomment the lines below to save on flash space if compiling for the APM using Arduino IDE
//#define OPTFLOW DISABLED // disable optical flow sensor to save 5K of flash space
//#define LOGGING_ENABLED DISABLED // disable dataflash logging to save 11K of flash space
//#define MOUNT DISABLED // disable the camera gimbal to save 8K of flash space
//#define CLI_ENABLED DISABLED // disable the CLI (command-line-interface) to save 21K of flash space
//#define AUTOTUNE DISABLED // disable the auto tune functionality to save 7k of flash
// redefine size of throttle deadband in pwm (0 ~ 1000)
//#define THROTTLE_IN_DEADBAND 100
//#define HIL_MODE HIL_MODE_SENSORS // build for hardware-in-the-loop simulation
// If Arduino IDE hang while uploading firmware to your board, try to change string below, just enter some random characters
//#define BOOTLOADER_BUGFIX "234fs34567"
#define BOOTLOADER_BUGFIX "fghfgh554f"
// User Hooks : For User Developed code that you wish to run
// Put your variable definitions into the UserVariables.h file (or another file name and then change the #define below).
//#define USERHOOK_VARIABLES "UserVariables.h"
// Put your custom code into the UserCode.pde with function names matching those listed below and ensure the appropriate #define below is uncommented below
//#define USERHOOK_INIT userhook_init(); // for code to be run once at startup
//#define USERHOOK_FASTLOOP userhook_FastLoop(); // for code to be run at 100hz
//#define USERHOOK_50HZLOOP userhook_50Hz(); // for code to be run at 50hz
//#define USERHOOK_MEDIUMLOOP userhook_MediumLoop(); // for code to be run at 10hz
//#define USERHOOK_SLOWLOOP userhook_SlowLoop(); // for code to be run at 3.3hz
//#define USERHOOK_SUPERSLOWLOOP userhook_SuperSlowLoop(); // for code to be run at 1hz
#define SERIAL_PPM SERIAL_PPM_DISABLED
//#define SERIAL_PPM SERIAL_PPM_ENABLED
//#define SERIAL_PPM SERIAL_PPM_ENABLED_PL1
// BLACK_VORTEX
GPS_PROTOCOL_NONE
GPS_PROTOCOL_NMEA
GPS_PROTOCOL_SIRF
GPS_PROTOCOL_UBLOX
GPS_PROTOCOL_IMU
GPS_PROTOCOL_MTK
GPS_PROTOCOL_HIL
GPS_PROTOCOL_MTK19
* options:
* QUAD_FRAME
* TRI_FRAME
* HEXA_FRAME
* Y6_FRAME
* OCTA_FRAME
* OCTA_QUAD_FRAME
* HELI_FRAME
