VERKAUFT Verkaufe All In One Pro Flight Controller V1.1- neu, in OVP
Wladi
Verkaufe All In One Pro Flight Controller V1.1- neu, in OVP für 45,-Euro + Versandkosten
Features:
·Supported MegaPirateNG and MultiWii firmware
·Up to 8-axis motor output
·8 input channels for standard receiver
·4 serial ports for debug/Bluetooth Module/OSD/GPS/telemetry
·2 servos output for PITCH and ROLL gimbal system
·A servos output to trigger a camera button
·6 Analog output for extend device
·A I2C port for extend sensor or device
·Separate 3.3V and 5V LDO voltage regulator
·ATMega 2560 Microcontroller
·MPU6050 6 axis gyro/accel with Motion Processing Unit
·HMC5883L 3-axis digital magnetometer
·MS5611-01BA01 highprecision altimeter
·FT232RQ USB-UART chip and Micro USB receptacle
·On board logic level converter
·Match the standard of RoHS
◆Flight mode for Multiwii
·One of the following basic mode
- Acro
- Level
- Alt Hold
- Head Lock
·Optional mode
- HeadFree (CareFree)
- GPS Hold (Need GPS receiver or Extend Board)
- GPS Back to home position (Need GPS receiver or Extend Board)
◆Flight mode for MegaPirate
·Acro
·Alt Hold
·Simple
·Loiter (uses GPS)
·Guided (uses GPS)
·Position (uses GPS)
·Circle (uses GPS)
·RTL (uses GPS)
·Auto(uses GPS)
·Follow Me(uses GPS)
◆Input power selection
·One of the following way
- Connect 5V power cable from ESC or UBEC to the ESC/Servo port, the J1 jumper must be closed.
- Connect 5V~12V power cable to the extend power port, the J1 jumper must be removed.
When using Extend Board, AIO PRO must be powered from the extend power port.
◆Other
·Dimension: 50mmX50mm
·Height: 11.6mm
·Weight: 14.2g
·Fixing hole spacing: 45mm
·Hole diameter: 3mm
◆Package content
·AIO PRO FC x 1
·3Pin to 1Pinx3 cable 100mm x 3
·3Pin to 3Pin cable 100mm x 1
·Molex 1.25mm 4Pin cable 100mm x1
·Molex 1.25mm 6Pin cable 100mm x2
·Molex 1.25mm 8Pin cable 100mm x1
