VERKAUFT Verkaufe GBM3506H 0.21mm 130 Turns Brushlessgimbal Motor Neu
Verkaufe neuen und unbenutzten GBM3506H 0.21mm 130 Turns Motor.
30,00€
Hersteller Daten:
GBM3506H-130T Hollow Shaft
Specs:
Model NO.:GBM3506-130T
Weight:64g
Motor Dimensions:42x14mm
Stator Dimensions:35x6mm
Copper wire(OD):0.21mm
Configuration:12N14P
Resistance:14.3 ohms
Wind type and termination method:Star style
Pre-wounded with 130 turns
Hollow Shaft: inner diameter 6mm,outside diameter 8mm,thickness:2mm
Bottom mounting holes: 16 and 19mm center to center
Top mounting holes: 12mm center to center
Camera range: 200-400grams
