Hallo !
Wegen Hobbyaufgabe verkaufe ich meinen Teradek Clip.
Er ist winzig klein und überträgt ein HD Bild direkt auf ein Apple oder Android Tablet.
HDMI Ausgang der Kamera direkt auf den HDMI Eingang des Teradek Clip.
Ich hatte ihn 2 mal im Einsatz und er funktioniert super.
Näheres siehe Videos auf Youtube oder unter teradek.com.
Neupreis : € 470,--
Verkaufspreis : € 330,--
Micro HDMI input
Streaming Resolution Support:
1080i 50/59.94/60
1080p 23.98/24/25/30
1080p 23.98/24/25
720p 50/59.94/60
576p
480p
H.264 Compression: Main & Baseline
Video Bit Rate: 150kbps to 5mbps
Built-in scaler & deinterlacer
2.4/5GHz a/b/g/n MIMO WiFi
Radio Output Power: 40mW
Audio Compression: AAC-LC, MPEG Layer 2
Embedded Audio (2 channel) Input (micro HDMI)
Audio Bit Rate: 16kbps to 256kbps
6-18V DC input barrel connector
Nominal power consumption: 3.5W
Dimensions: 66 x 49 x 17mm
Weight: < 2 Oz
Technische Beschreibung :
Micro HDMI input
1080i 50/59.94/60
1080p 23.98/24/25
720p 50/59.94/60
576p
480p
Weight: < 2 Oz
The Teradek Clip is the world's smallest and lightest H.264 transmitter developed specifically for unmanned aerial vehicles. Clip gives copter pilots a powerful HD video transmission solution for low latency monitoring on iOS devices over 2.4/5GHz WiFi. Clip has a micro HDMI input, dual RP-SMA jacks for high gain antennas, and can transmit up to 300ft without a router.*
*Range can be greatly extended using routers and directional antennas.
Small Size, Low Power
Clip is about the size of a matchbox, requires little power, and weighs approximately 2 ounces. This means you never have to worry about sizable increases to your copter's payload or inefficient power draw that may quickly deplete onboard batteries.
TDS Support
To ensure a robust low latency video transmission, Clip utilizes the custom TDS transport protocol, which allows you to fly in and out of range without having to restart the transmitter. Clip is also capable of transmitting to Cube decoders using TDS and to Wirecast and TriCaster systems using our free Stream Reader plugin.
Real-Time Monitoring on iOS Devices
Clip transmits directly to iOS devices at less than 4 frames of latency*, giving you a first person view of your UAV's flight path in real time.
This is Just the Beginning
Clip has a number of upcoming accessories that will allow you to monitor your footage on multiple devices, stream to decoders for point to point broadcasts, and extend the range of your wireless transmission by hundreds of meters.
Neupreis : € 470,--
Micro HDMI input
1080i 50/59.94/60
1080p 23.98/24/25
720p 50/59.94/60
576p
480p
Weight: < 2 Oz
Micro HDMI input
1080i 50/59.94/60
1080p 23.98/24/25
720p 50/59.94/60
576p
480p
Weight: < 2 Oz
TDS Support
