du meinst PWM – Pulse Width Modulation
PPM – Pulse Position Modulation
PPM is also known as CPPM or PPMSUM. The advantage of PPM is that only one signal wire is needed for several channels (typically 8 channels max), instead of a number of individual wires. So you should only connect the ground, power and signal cable.
Aber egal ich glaub wir meinen beide was ähnliches...
allerdings wenn sein Empfänger nur CPPM rausgibt, dann sollte er umlöten sonst wird's nix´...
