Software zur Antennen-Berechnung z.B. für Helix, Yagi, etc.
GP-Patch-Antenne
bauanleitung einer patchantenne
http://www.rc-cam.com/gp_patch.htm
Q: I have two video systems that operate at 900Mhz and 1.2Ghz. Can I use the GP Patch?
A: You can use it at other UHF and microwave frequencies by re-scaling the design. This is a process where ALL the dimensions are increased to suit the required operating frequency. It is important to know the exact frequency of your system, so a frequency counter is often needed.
To scale the antenna for your required frequency please use this formula:
Scale Factor = 2400Mhz / Required Mhz
Example: Cheap imported "1.2Ghz" wireless video system (usually operate at 1.16Ghz):
2400Mhz / 1160Mhz = 2.069
Nabazul
nach der gefühlt 35.ten Bauanleitung wie man zu Antennen mit Heißkleber dran nach USA Cookbook Recipe kommen kann, hier mal einige sachliche Bemerkungen zu dem Thema oder frei nach D MAX
Antenna Mythbusters
http://fpvlab.com/forums/showthread...k-seriously-about-antennas-or-10-myths-busted
nett und informativ, wie da so manche heisse Luft abgelassen wird
Guten Flug
PeteR
das beste an dem link ist diese Drahtbiegemaschine das sieht sau cool aus.
