Hier mal aus einem englischen Forum. Das könnte meinen Verdacht bestätigen.
Re: Cheap u-blox Neo-M8N from Banggood - First Impressions
« Reply #14 on: April 26, 2015, 10:25:42 »
I'll try and find it, it didnt directly relate to this issue anyway but did have the settings i needed buried within...
But essentially mine was set to SPI communication as opposed to UART which is needed by APM, also the BAUD RATE was wrong (57600 instead of 38400)
The settings were changed in ucenter, once connected to your GPS press F9 for 'Message View' then under UBX select CFG (config), PRT (ports), Then set 'Target' to UART1, 'Protocol in' doesn't matter, mine is now set to UBX + NMEA, same for protocol out, then set the baud rate to 38400, save settings to gps... (You do this by going to UBX>CFG>CFG>Save Current configuration, then pressing 'Send' in the bottom left
Or if you try to exit 'message view' without saving it'll prompt you"
