FrSky is developing many new products at simultaneously, and will release in market soon. There blow is the brief introduction and estimate release date for these new products:
Also, we would like to take this opportunity to collect new products suggestions, you are welcome post it at the following.
S.PORT Support Sensors:
1. FAS-40S (FrSky Ampere Sensor-40A for S.Port)
Already released at early of November!
Dimension: 61.2×16.7×13.2mm Weight: 17g
Measurement range: 0~40A
Current consumption: 25mA@5V
Maximum safe current: 40A
Compatibility: FrSky Smart Port enabled receivers, such as X8R, X6R, X4R, etc.
2. FLVSS (FrSky Lipo voltage sensor for S.PORT)
Already released!
Supporting 2pcs+ FLVSS sensor connection on S.PORT bus to detecting total 12cells + voltages, which is max. Support 16pcs same sensors connect on S.PORT bus. The PC program for sensors ID configuration will supplied, also the new telemetry display screen FSD is supporting the ID configuration.
3. GPS (FrSky GPS V2 for S.PORT)
Estimate available at early of Dec. 2013
4. FSD (FrSky Smart Dashboard)
Estimate available at the end of Dec. 2013
This product will integrate many new features, such as voice, SD card data logger, usb interface, SMART Port etc. , the main screen will apply 2.4’ OLED
5. SPORT adapter- SP2UART
Estimate available at end of Nov. 2013
Functions: 1, support date-transmission between serial analog ports at S.PORT BUS.
2, support two analog signal input vis S.PORT
6. FAS-100S ((FrSky Ampere Sensor-40A for S.Port)
Estimate available at end 2013 or early January
7. Air Speed sensor & RPM
Estimate available at January or February of 2014.
X-series Receiver: X6R
Estimate available at middle of December.
- Six physical channel
- S.PORT, SBUS, RSSI support
- Built in external analog AD port.
Servo:
Three modes SBUS support servo estimate available at December!
Radio: Taranis X9D +
Estimate available within two months.
The Taranis X9D+ will have some new features and functions over the Taranis X9D, including haptic, upgraded sliders, dual-color LED backlight grey-scale display, 6-position replaceable encoder, etc.
* Current Taranis X9D radio can obtain parts of new X9D+ features via components replacement and firmware upgrade.
