Davon mal abgesehen, dass man den Disco nun bereits bei Saturn sowie Parrot bestellen kann, die Anleitung gibt schon mal interessante Einblicke:
https://www.google.de/url?sa=t&rct=...sg=AFQjCNGioEmqTH8K97HqqOcxXZ8DZVmTlg&cad=rja
Man kann seine eigene Fernsteuerung einbauen, hat dann aber nur den rein manuellen Modus:
MANUAL MODE
You can use an RC remote (not included) to fly the Parrot Disco.
Manual mode offers no piloting assistance for the Parrot Disco.
Configure the channels of your RC remote for the Parrot Disco.
To do this, refer to the manual for your RC remote.
The Parrot Disco is difficult to control without the assistance of
the autopilot. This mode is for expert pilots.
TECHNICAL SPECIFICATIONS
SENSORS
• Ultrasound
• Altimeter
• Hi-speed vertical camera
• Pitot Tube: speed sensor
INERTIAL NAVIGATION SYSTEM
• Three-axis gyroscope
• Three-axis accelerometer.
• Three-axis magnetometer
HARDWARE
• Dual core ARM 9 CPU
• Internal flash memory: 32GB
WI-FI AND TRANSMISSIONS
• Network access point
• .AC Wi-Fi, 2 dual band antenna (2.4 and 5 GHz), multiple inputs
and outputs
• Up to 2km of range with the Parrot Skycontroller and the Parrot
Skycontroller 2.
REMOVABLE BATTERY
• 3 cell 2700mAh / 25A LipoBattery
• Battery life: 45 minutes
• Rated voltage: 11.1V
• 21.6A continuous discharge
• 3.5A max charge
• Operating range: -20°C-60°C
ENGLISH
DIMENSIONS
• Weight: 750 gr.
• Size: 1150 mm x 580 mm x 120 mm
• Wingspan: 1150 mm
GPS
• Integrated GPS
• GPS + GLONASS
PERFORMANCE
• Engine: 1280kv
• Servomotor: 5V
• Option of installing an SBUS, SUMD, CPPM radio receiver
VIDEO & PHOTOS
• Full HD 1080p Camera
• Video feed: 360p / 720p
FIRMWARE
• Linux & Open Source SDK for development
BATTERY CHARGER
• Input: 100-240V, 50h-60Hz, 1.2A
• Output: Max 12.6Vdc, 3.5A
• Maximum altitude: 2000m above sea level
• Operating range: 0°C-40°C
PARROT DISCO
• Max current: 15A
MANUAL MODE
SENSORS
• Ultrasound
• Altimeter
HARDWARE
and outputs
Skycontroller 2.
REMOVABLE BATTERY
• 3.5A max charge
ENGLISH
DIMENSIONS
• Weight: 750 gr.
• Wingspan: 1150 mm
GPS
• Integrated GPS
• GPS + GLONASS
PERFORMANCE
• Engine: 1280kv
• Servomotor: 5V
VIDEO & PHOTOS
FIRMWARE
BATTERY CHARGER
PARROT DISCO
• Max current: 15A
