Hier mal ein Dokument mit den Specs:
http://cdn0.vox-cdn.com/assets/4438735/FINAL_Parrot_BeBop_Drone_USA.pdf
Hammer was die alles an Sensorik verbaut haben....
Bebop Drone integrates data coming from numerous sensors:
o One 3-axis accelerometer
o One 3-axis gyroscope
o One 3-axis magnetometer
o One ultrasound with a reach up to 8 meters
o One pressure sensor
o One vertical camera
A MIMO Wi-Fi connection
The Parrot Bebop Drone is equipped with 4 Wi-Fi antennas so it can manage the 2.4 GHz and 5 GHz frequencies in MIMO (Multiple Inputs Multiple Outputs) format.
The Wi-Fi liaison uses the latest Wi-Fi 802.11ac.
Depending on network interference, the pilot can select the frequency of his choice.
The Parrot Bebop Drone integrates a GNSS chipset that associates the GPS, GLONASS and GALILEO data. The Bebop Drone is capable of autonomous flight and automatic return to the take-off position.
The Bebop Drone automatically records the data of each flight on Parrot cloud: “Pilot Academy”.
und noch ein paar Daten:
CPU Dual core A9
− Linux
− Open source SDK
− Wi-Fi:
. Wi-Fi 802.11 a/b/g/n/ac
. Wi-Fi MIMO 2.4 and 5GHz
. 26dBM
− GNSS : GPS+Glonass+Galileo
− Inertial unit: Gyroscope, Accelerometer, Magnetometer, Altimeter, Ultrasound, Vertical camera.
− Battery : Lithium Polymere 1200mAh
− Flight time: Around 12 minutes
− Compatibility: iOS and Android Smartphones/tablets
− Weight: 380g
und das Ding mit EPP Drum lass ich mir lieber auf den Kopf fallen als nen Phantom ;_)
