TBS GEMINI (kleiner FPV-Hexa)
klemmi86
bin gerade über die Info gestoßen, dass TBS einen kleinen Hexa rausbringen will und er angelehnt an den Shrediquette mit einem Jello-Free-Möbius-Mount.
[video=youtube;qsoItjqaz8w]https://www.youtube.com/watch?v=qsoItjqaz8w#t=23[/video]
von FPVlab:
The TBS Gemini is available as a 5.8GHz or 2.4GHz video variant. It comes delivered in a protective case according to your specification (see customization options below). Assembly takes a few minutes as you add props, choose between the race and film setup and secure the canopy. A full slew of spare parts will be available after the preorder phase.
Availability
The preorder is expected to go live towards the end of August. We will announce the exact date and time here once known. The first batch is severely limited, and the 2nd batch will take care of all preorders. Batch 1 will be shipped out end of September, Batch 2 is also in production but will take another 3-4 weeks.
Features
Forward-tilting motors for efficient, high speed flight
Built-in FPV camera
Optional HD camera
CORE OSD/power supply with integrated current sensor
Ready for long range FPV
Custom 4A ESCs
Taulabs-based flight control
Crash-friendly, yet integrated layout
Package includes
TBS Gemini main frame and plastic parts
Canopy for Race and Film (Mobius camera)
6 motors, ESCs and props
Flight control, pre-configured
CORE PNP25 (optionally upgrade to CORE PRO)
FPV camera
TBS BOSS 5.8GHz (optionally upgrade to 2.4GHz)
1x 3S Battery
FAQ
When can I order? - End of August
What is the price? - Less than 600 USD for a ready to fly package, without receiver
When can you deliver? - Late September
Can I add a GoPro? - Yes. But we won't have a plastic dome for it. And we don't recommend it. The Mobius camera is suggested!
G
Gelöschtes Mitglied 1973
empfänger muss man natürlich den einbauen den man haben will ^^
mit UHF wird das schwierig, wie auf jedem mini quad mit den störquellen ;/
Merlinfly
Das ist durchaus positiv, aber hat jemand weitergehende Infos.
Wie gross das der Empfänger sein, hat ja wohl nicht viel Platz, Summensingal?
Exec
Die FC namens Colibri soll wohl ein verkleinerte Variante vom Quanton sein (Taulabs FC mit STM32F4).
Im Taulabs Forum findet man auch was dazu http://forum.taulabs.org/viewtopic.php?f=6&t=219 .
Habe mal einen kurzen Blick in die Gerber Dateien geworfen ca. 27.6mmx27.6mm, und Abstand der Bohrugen (Mitte zu Mitte) ca 23mm. Also schon ziemlich kompakt.
Habe es mir noch nicht genauer angeschaut, aber da werden bestimmt ein paar I/Os vom Qunaton weggefallen sein.
infinity553
Als Empfänger sollen S-Bus so wie PPM Empfänger gehen.
Ich werde einen X4R von FrSky via S-Bus reinstecken.
D4R-II werden ansonsten empfohlen von TBS.
Der GR12 (normal) passt auch nicht an den vorgesehen Platz. Der GR12L sollte aber passen. Es gibt wohl noch einen "Backupslot" wo auch größere Empfänger untergebracht werden können. Mehr Infos wenn die Kisten dann Ende Oktober bei mir eintreffen.
Habe ich auch gedacht. Geht aber erstaunlich gut. Das einzige worauf man achten muss ist dass der Videosender nicht allzuviel Leistung hat sonst macht der den Empfänger dicht. Mit meinem Openlrs-Mini-RX bin ich bis jetzt 1km geflogen mit ca 70% RSSI, das ist in Ordnung.
UHF ist bei den Minis halt endgeil weil man 0,0 Schwierigkeiten im Wald bekommt. Mit 2,4Ghz Video ist das dann wirklich geil. Da wo die 5,8er Quads schon an den Bäumen kleben dank fehlendem Videobild und RC-Link hab ich immer noch eine glasklare Übertragung.
Hier ein paar Bilder:
Fliegt so weit ich es testen konnte sehr gut und funktioniert aus dem Koffer raus mit der Fatshark Predator Brille. Sofern das Wetter mit macht, kommt bald ein Video.
Ja ist out of the box. Fliegt zahm und die raten sind auch recht lahm eingestellt. Ich musste nach dem Testflug im Video die Gaskurve erst mal anpassen und die raten von 360° auf 475° hochschrauben. Jetzt fühlt es sich schon besser an. Leider bin ich dann nicht mehr zum fliegen gekommen zwecks dunkel und so :D. Da ist aber definitiv noch Spielraum nach oben da. Die TBS Jungs haben den Gemini wohl für Naza GPS flieger eingestellt.
